Author Topic: Help or the omega gets IT....Lol  (Read 2185 times)
gstylebaby
  • stockport
« on: 24 May 2009, 18:05:12 »
Hi fellas,
As some of you know i have been having some trouble i did a cam cover gasket change two weeks ago now and then did a paper clip test and got code 19 incorrect r.p.m signal have changed the crank sensor as recommended today and then re-did paper clip test and i'm still getting code 19  >:( >:(....Were do i go from here fellas cause  i have had no car for two weeks now due to the fact i work shifts and getting parts etc...I did not change the inlet gaskets and did not change the plenum o'rings could this be my problem ???? I want to hit it with a large hammer but that would only cost me more. ;D ;D
HHHelp please........ >:(
« Last Edit: 24 May 2009, 18:11:58 by gstylebaby »
Re: Help or the omega gets IT....Lol
« Reply #1 on: 24 May 2009, 18:40:12 »
How long since you changed the sensor?
gstylebaby
  • stockport
« Reply #2 on: 24 May 2009, 19:29:32 »
done it today mate.
gstylebaby
  • stockport
« Reply #3 on: 24 May 2009, 20:20:24 »
Anyone ????
« Reply #4 on: 24 May 2009, 21:11:56 »
Anyone ????
Sorry Lee   :(  ;)  ;)
MutantCav
  • Gainsborough
« Reply #5 on: 24 May 2009, 21:36:40 »
ECU can retain error codes for 20 startups after its fixed...may be a not present code...if so it will go away soon
« Reply #6 on: 24 May 2009, 21:41:19 »
That's a point! :-? Did you clear the ECU after fitting your new crank sensor?  :-/  :y  :y
gstylebaby
  • stockport
« Reply #7 on: 24 May 2009, 22:12:53 »
No mate how do i do that do you need tech one / two to do it.  The fault did go at one point but then the car would not start just kept popping and farting then stall. The code's i got at that point were 12 and 31 which is normal...Took the idel air control valve off gave it a clean put it back in and it started o.k but then the code 19 was back. I have got another code coming up which is 135 but put that down to the fact i have a lamp out on the display.
« Reply #8 on: 24 May 2009, 22:26:26 »
As Mutantcav/Chris says, the fault code will be wiped from the ECU after about 20 'clean' starts or with a real or Cheapo Tech II.
Is you EMl still on or has it now gone out? If it's out, then the ECU is happy, but has remembered the previous faults.
« Last Edit: 24 May 2009, 22:26:37 by Andy_B »
gstylebaby
  • stockport
« Reply #9 on: 24 May 2009, 22:33:30 »
My e.m.l has not bean on at all until today when i left the bloody plug off the idel air control valve i'm only getting the 19 code from the paper clip test the e.m.l was never on mate ???? Will have a go at the 20 starts tomorrow see what that does thanks for all the advice fellas...I just want to drive my omega again. :'( :'(
« Reply #10 on: 24 May 2009, 22:36:22 »
You can always come & borrow my 'cheapo Tech II' if you think it'd help.  lappy with serial port required :y
gstylebaby
  • stockport
« Reply #11 on: 25 May 2009, 01:19:11 »
Thanks for the offer mate but dont have a lap top....Will try the key thing and i think a mate of mine has a tech device not sure but if he has i'l get him to have a look...Thanks again andy. :y :y
mathewst
  • Split, Croatia
    • v40
« Reply #12 on: 25 May 2009, 09:59:12 »
I also had some problems so will have to check the crank sensor.
How dificult is it to change? Also what is the price of the new one?
Cannot do a paperclip test cause the car is 2.2 petrol >:(
gstylebaby
  • stockport
« Reply #13 on: 25 May 2009, 16:20:28 »
Not that hard mate 1 bolt that holds in it next to the oil filter and then plug at the top....Just remembered yours is a 2.2 but still don't think it would be that hard.
gstylebaby
  • stockport
« Reply #14 on: 25 May 2009, 16:24:18 »
Well cleared the e.c.u doing the key trick and now not only do i have my code 19 but i also have 57 idel air control voltage low ??????  >:( >:( >:(
Now i'm more lost than i was before.
