Author Topic: Central Locking won't unlock  (Read 1073 times)
Alex
  • Hexham,  Northumberland
« on: 25 May 2009, 12:47:29 »
Cenral locking problem on 3 litre MV6.  Everything was working ok but this morning can't unlock the vehicle either by the remote or manually.  Anybody got any ideas please (and how to I get into the damned thing to fix whatever may be the problem?)
lou
  • Romford
  • Always expect the unexpected
Re: Central Locking won't unlock
« Reply #1 on: 25 May 2009, 16:33:04 »
Put the key inte driver side and turn clockwise as hard as you can...almost as if you will break the key. First time it happened to me I took it to my garage and well you can imagine how I felt when they just put the key in it and turned.(It will work). There are other ways , but try this first...
Alex
« Reply #2 on: 25 May 2009, 17:37:03 »
No joy turning key....seems to reach a detent which it clicks past and then nothing.  I have noticed that the dashboard alarm indicator light isn't flashing, could it be the control unit or something as daft as a flat battery?  Still need to get into the car though.
« Reply #3 on: 25 May 2009, 17:41:10 »
Once the key passes through the point of resistance try the door handle. The lockpin does not pop up but it should be unlocked.
Alex
« Reply #4 on: 25 May 2009, 18:22:04 »
Thanks for your help, that worked perfectly.  Still can't start the car (no ignition & alarm sounds) but I think a new battery in the key might be the first place to start.  Make note to self...."Do not leave handbook in car ever again"
