Author Topic: O ring?  (Read 1096 times)
O ring?
« on: 25 May 2009, 18:11:58 »
O ring under oil filler neck on V6.
Anyone ever had trouble with this?
Never seen one fail before - but mine seems to be leaking oil, whch is running down the side of the cam cover onto the exhaust manifold.
Something new every day  ::)
Re: O ring?
« Reply #1 on: 25 May 2009, 18:32:30 »
Yes, seen them fail. Replacement normally fixes it.
A member here had an issue even after replacing
Re: O ring?
« Reply #2 on: 25 May 2009, 18:44:23 »
What's the fix if replacing doesn't fix - new neck too? :y
Richard A
  • Aldridge, West Midlands
Re: O ring?
« Reply #3 on: 25 May 2009, 18:52:25 »
I had to replace the 'cap', the neck was fine.
regards
richarda
richard a
Re: O ring?
« Reply #4 on: 25 May 2009, 19:00:19 »
check its not leaking where the 2 parts of the neck are joined.
Re: O ring?
« Reply #5 on: 25 May 2009, 20:10:12 »
There are two of these o rings - one in cap, other lower down.  Replaced both on Estate - seems to have stopped leakage which I suspected was cam cover gaskets.  Both O-rings same size.
Page created in 0.063 seconds with 20 queries.
