Author Topic: Cam cover oil seals changed ....now what !!  (Read 2520 times)
Missy_MV6
« on: 24 May 2009, 14:30:48 »
Hi Guys
I mentioned that we have an oil leak on the MV6 and it's not obvious where it is coming from ,so after reading the forum it sounded like it could be coming from the cam cover..Bought all the bits from Vauxhall,
Printed the "How to" guide off here (which is fab)
My hubby got it in bits and there is no oil leak whatsoever coming from there, the breather pipes are clean,nothing at all is blocked,the plug wells are not full of oil...He has fit new parts and popped new plugs in anyway.
Just worrying that we don't know where the oil is coming from..
Any suggestions :-/
Angie x
ScottieMV6
  • Swinton, Manchester
Re: Cam cover oil seals changed ....now what !!
« Reply #1 on: 24 May 2009, 14:58:38 »
What are the symtoms Missy? Can you see oil anywhere?
Oil cooler unions perhaps?
I'd rather be scared to death than bored to death!!
« Reply #2 on: 24 May 2009, 15:04:06 »
Hi Guys
Any suggestions :-/
Angie x
as said bt m ore inf needed i think...do you ave the oliginal thred? Sory having trouble concentreartingg... :o
Missy_MV6
« Reply #3 on: 24 May 2009, 15:18:24 »
It looks like oil is dripping onto the pan , front passenger side and then our drive slopes downward so when the car is parked the oil drips from the pan onto the floor in that corner. :-?
Angie x
« Last Edit: 24 May 2009, 15:26:10 by Missy_MV6 »
« Reply #4 on: 24 May 2009, 16:22:33 »
Angie x
Leaky oil filter?
Or as said above leaky oil cooler pipes/connections?
ScottieMV6
« Reply #5 on: 24 May 2009, 16:29:24 »
Only other thing I can think of is oil filler neck not on properly or dipstick tube?  :-/
Missy_MV6
« Reply #6 on: 24 May 2009, 17:01:52 »
Well all the bits are back in the engine and it runs  ;D..He has just done an oil change and the new oil filter had a brass/copper washer that came with it.We were told it goes on the sump.My hubby has fit it but there wasn't one on there to start with :o ..would this cause it to have a small oil leak if the washer was missing ?
Angie x
ScottieMV6
« Reply #7 on: 24 May 2009, 17:35:54 »
Didn't think they had a washer on the sump plug in 99. Pretty sure mine doesn't have one and its a 98.
I could be totally wrong though in which case I need to get one for mine!  :o
Missy_MV6
« Reply #8 on: 24 May 2009, 17:43:15 »
The guy at Vauxhall (who is pretty good) knows the age of our car etc and he ordered the parts..the washer was taped onto the side of the oil filter box :)
Angie x
ScottieMV6
« Reply #9 on: 24 May 2009, 17:52:28 »
Have a look here http://www.omegaowners.com/forum/YaBB.pl?num=1167519662. Seems there are two types of sump plug. The old hex one has a washer and the torx one doesn't. Mine is definitely a torx one!  :y
« Last Edit: 24 May 2009, 17:53:34 by scottie7275 »
Missy_MV6
« Reply #10 on: 24 May 2009, 18:01:35 »
Well I have just been informed that ours is the Torx type too.So ..because we have fit the washer do you think it will leak now  :-/
Angie x
ScottieMV6
« Reply #11 on: 24 May 2009, 18:07:08 »
I'm no expert but I suppose its possible. I know that mine doesn't leak without it!  :-/
Missy_MV6
« Reply #12 on: 24 May 2009, 18:27:08 »
Lol...time will tell I suppose..fingers and toes crossed the leak has now gone ;)
Angie x
« Reply #13 on: 24 May 2009, 18:42:08 »
Oil presuure switch and front crank seals are other possibilities
    • 530D M Sport, 330i Coupe
« Reply #14 on: 24 May 2009, 21:29:53 »
Other things to check are:-
Power steering fluid (from the pump) running down - therefore getting dirty.
Cam Seal - not really a lot of oil but runs down the front of the block behind the rear cambelt cover.
