Author Topic: Cam cover oil seals changed ....now what !!  (Read 2521 times)
Missy_MV6
Re: Cam cover oil seals changed ....now what !!
« Reply #15 on: 25 May 2009, 19:21:22 »
Other things to check are:-
Power steering fluid (from the pump) running down - therefore getting dirty.
Cam Seal - not really a lot of oil but runs down the front of the block behind the rear cambelt cover.
Thanks for that  :)
Angie x
« Reply #16 on: 25 May 2009, 20:14:16 »
Torx sump plug should have an O-ring fitted!
Check also oil filler O-rings - see http://www.omegaowners.com/forum/YaBB.pl?num=1243271518
