Author Topic: Compressor still won't fire up  (Read 1651 times)
« on: 25 May 2009, 19:28:26 »
Not really investigated properly - but - My aircon compressor still won't fire up - clutch seems to stay still with climate on or off
Checked the electrical connectors, and can't see any obviously blown fuses.
Any ideas? :y
Re: Compressor still won't fire up
« Reply #1 on: 25 May 2009, 19:28:46 »
Just to add - this is mainly only a pain because idle is a tad low, and occasionally she hunts...
Martin_1962
« Reply #2 on: 25 May 2009, 19:39:17 »
Gas pressure?
« Reply #3 on: 25 May 2009, 19:40:22 »
does your outside temp sensor work?
unlucky mark mv6
  • tipton,west mids
« Reply #4 on: 25 May 2009, 19:40:34 »
Seized.
« Reply #5 on: 25 May 2009, 19:57:42 »
James - pull plug on a/c compressor.  Put 12v across compressor terminals (observe correct polarity) - you should hear clutch engage with a clunk.  If no clunk clutch breaked.  If clunk look elsewhere.
« Reply #6 on: 25 May 2009, 20:54:01 »
Far more likely low on gas....
puffa
  • Southampton, UK
« Reply #7 on: 25 May 2009, 21:14:40 »
sorry to hijack your thread, I have the same trouble, the compressor wheel turns freely however when you switch the aircon on it stays still, is there a relay that swithes over when the you switch the aircon on? if so where is it?, just a thought before spending £65 plus for a regas?
Steve.
Previously owned 2.5 v6 Reflection
« Reply #8 on: 25 May 2009, 21:16:15 »
Steve.
Most likely low gas...
puffa
  • Southampton, UK
« Reply #9 on: 25 May 2009, 21:17:51 »
Steve.
ok thanks TB..
« Reply #10 on: 25 May 2009, 21:18:52 »
All respectable a/c places can measure gas pressure before committing to vac and refill
puffa
  • Southampton, UK
« Reply #11 on: 25 May 2009, 21:21:37 »
Nice one, i had not thought of that, will drop into my local a/c place tommorow and ask if they will check the pressure... thanks.
steve
