Author Topic: Refitting cams - getting the timing into position  (Read 2763 times)
Re: Refitting cams - getting the timing into position
« Reply #15 on: 25 May 2009, 22:27:13 »
Try this
Page says
.o...o................o
1.....2........3.....4
...............o......
I get
o........o.............o
.1.....2........3.....4
Is this to be expected?
You've lost me with your 'pictures'  :-/  ::)  ::)
What do thet represent?  :-[
« Reply #16 on: 25 May 2009, 22:33:56 »
The crank on a V6 is safest at 4 o clock... :y
« Reply #17 on: 25 May 2009, 22:37:14 »
but it's taken Martin days now not hours!!! ;) ;) ;) :y
When you say the crank at 4 o'clock, I assume you mean TDC is at 4 o'clock :-/ :y
Martin_1962
« Reply #18 on: 25 May 2009, 23:10:12 »
I was still dismantling the inlet at 4 oclock, finished about 6 tonight after a 7:30 start this morning.
IF Bicknells can get an HG by dinner time change, else risk reuse I have decided.
Martin_1962
« Reply #19 on: 25 May 2009, 23:11:58 »
So far
Hard bits
DIsmantling due to loctite and previous bodging
refitting heads
that coolant pipe down side of engine
Actually the cam belt was not difficult
However 3 days solid has taken it out of me a lot now and I am shattered
« Reply #20 on: 25 May 2009, 23:14:28 »
I wouldn't have thought that a few miles with the gasket the wrong way up would damage it ?? It is designed to take a fair bit more stress than that I would have thought ??
« Reply #21 on: 25 May 2009, 23:19:06 »
It's not the head gasket that the worry, it's the lack of oil due to the gasket being the wrong way round. :-?  If you look at the eBay picture, the oil hole is at the side of the gasket/head & if the gasket is 4r$e about face it'll block it which ever upside down it is.  ;)
