Author Topic: auto gear lever  (Read 1417 times)
eddie h
  • burton on trent
auto gear lever
« on: 23 May 2009, 21:20:42 »
Hi just got the wife a 2.0 face lift,got fed up with her nicking my 2.5 cdx, the thing is the auto gear lever is sloppy for want for a better word,any one got any thoughts on it or will i have to replace it. thanks every one
unlucky alf
  • worksop, notts
Re: auto gear lever
« Reply #1 on: 23 May 2009, 22:58:51 »
i think the gear lever when not connected to the box just waves about, so going on that i would have thought its the g/box itself as it has a stepper type ratchet affair, perhaps its the latch on that which is a bit sloppy, if you do decide to change the lever though youll find it is rivetted to the transmission tunnel :y
eddie h
  • burton on trent
Re: auto gear lever
« Reply #2 on: 23 May 2009, 23:11:09 »
yes i think it may be the ratchet , there just seems to be alot of free play between the gear selections compaired to my cdx
unlucky alf
  • worksop, notts
Re: auto gear lever
« Reply #3 on: 23 May 2009, 23:22:56 »
perhaps its just the selector rod that might need an adjustment, or maybe a worn pin or hole where the lever connects to the box if you know what i mean :D
eddie h
  • burton on trent
Re: auto gear lever
« Reply #4 on: 26 May 2009, 11:51:44 »
Sorted took all of 5 mins, the nut that holds the lever to the box was loose,thanks for your input
