Author Topic: lumpy tickover  (Read 2448 times)
beemerdevil
lumpy tickover
« on: 24 May 2009, 14:01:47 »
Hi chaps....
anyone any ideas?? - last few days (car has been sitting all week)  got in it, started ok then when putting into 'D' and holding it on brake, it seemed like it was 'lumpy' and slight 'miss' ? - put into drive and ok....no probs when driving, and seems ok when driven for a bit and warmed up.
am thinkin damp? as its bin standin a while - have never had this before.  welcome your thoughts/ideas -  :y TIA    :y :y
beemerdevil
Re: lumpy tickover
« Reply #1 on: 24 May 2009, 15:53:52 »
Hi chaps....
ANYONE ????????????
al brown
  • alton, hants
    • Rusty 97 3l estate
Re: lumpy tickover
« Reply #2 on: 24 May 2009, 17:11:14 »
Hi, Did you have A/C on. May be damp but to be honest I have had mine sat for 2 months while I was a way more than once and its never been a problem on first start. Maybe worth doing pedal trick to see if it logged anything.
Al
If it aint broken, you aint trying hard enough
Welung666
Re: lumpy tickover
« Reply #3 on: 24 May 2009, 17:21:21 »
Check the plug wells for oil aswell
Ghost
  • Seaham, North East england
    • 2.6 V6 CDX Estate
Re: lumpy tickover
« Reply #4 on: 24 May 2009, 18:21:28 »
Try the paperclip test it might help. can you take the revs up higher than 4500rpm when driving? or does it start to stutter?
He who brakes Looses
To old to die young
beemerdevil
Re: lumpy tickover
« Reply #5 on: 25 May 2009, 12:13:45 »
Hi guys...thnx for ur help/comments. - hmmm its strange.....yea, i can floor it and rev it high...no probs.
went out this morning; had the same - ok starting; ok tickin over in P; soon as i put it into D it is lumpy/intermittent missin sort o thing.  Then, on way home, went into a slight right hand bend about 45/50, as i straightened, it was missin and then EML came on, was flashing, then went off - then it drove ok/normal. hmmmmmm strange one.
i will do the p/clip test see if anything comes up - cheers guys for your help - catch u later  :y :y
Tonybazza
  • Lapford Devon
Re: lumpy tickover
« Reply #6 on: 25 May 2009, 12:30:19 »
Hi just a quick thought but only a novice could this be shi--t in the petrol tank or fuel filter i had the same on a rover sterling auto if i went around a corner or stopped quick . found that i had more water in the tank than petrol and as you say you had the car standing for awhile has water got in the tank somehow? on the rover it had a fuel filter in the engine bay i found rust and water in it to a level that it could tick over ok but if the car would go on a slant it would block the filter outlet pipe the missing was the car trying to run on water.but we drove from Devon to Grantham like that last year before i found out what it was so what people might say about rovers (they do run well on water lol lol).
just a thought but as i say just a novice
beemerdevil
Re: lumpy tickover
« Reply #7 on: 25 May 2009, 12:49:24 »
Right.......just done pedal test...and got..
10  4  4  3
10  3  10  10
10  3  10  5
?????? totally baffled??????
what might these codes mean please??   :-? :-? :o :question :question :y
TIA
« Last Edit: 25 May 2009, 15:11:09 by beemerdevil »
beemerdevil
Re: lumpy tickover
« Reply #8 on: 25 May 2009, 14:17:49 »
bump
beemerdevil
Re: lumpy tickover
« Reply #9 on: 25 May 2009, 15:14:58 »
pedal test results:
10  4  4  3
10  3  10  10
10  3  10  5
can anyone tell me what these are please ??
TIA  :y :y
Ghost
    • 2.6 V6 CDX Estate
Re: lumpy tickover
« Reply #10 on: 25 May 2009, 16:18:10 »
Sorry I cant find my code list. one of the senior members might be able to help, try and ask Theboy he has good knowledge about the codes.
To old to die young
Re: lumpy tickover
« Reply #11 on: 25 May 2009, 17:23:02 »
pedal test results:
10  4  4  3
10  3  10  10
10  3  10  5
0443----- Possible very slight leak in one of the vacumn pipes to the purge valve or purge valve stuck closed or inoperative (release fuel filler cap, if a "whooshing" type sound heard, points to purge valve probs.
0300------ random misfire
0305------ random misfire on No: 5 cylinder.
Check plugwell for oil,and any signs of damage on No;5 coilpack.
beemerdevil
Re: lumpy tickover
« Reply #12 on: 25 May 2009, 19:48:05 »
Brilliant.....cheers Rob  :yerrr...next question? - where is the purge valve sited, and should i renew it?
TIA  :y
beemerdevil
Re: lumpy tickover
« Reply #13 on: 26 May 2009, 16:30:22 »
bump
Welung666
Re: lumpy tickover
« Reply #14 on: 26 May 2009, 16:41:04 »
Please take a moment to re-read the forum rules. Bumping is not allowed.
