Author Topic: Trip Computer Fault  (Read 3389 times)
Re: Trip Computer Fault
« Reply #15 on: 03 June 2009, 16:20:15 »
The trip computer in our Elite shows a greater range as the fuel level drops, can anyone tell me why & how to fix this fault.
This is quite normal. The range shown depends on how the car has been driven for the past 7 and 21 miles, how much fuel is in the tank, and the fuel quality.
If I fill my 2.5 V6 CDX during a long motorway journey, the range will be about 470 miles. Depending on how I drive for the next 100 miles that figure can go as high as 640 miles, or will drop rapidly.
If you give it welly up a long hill the numbers will drop rapdly, but will climb again as you go down the other side.
The important point is, the numbers should drop to zero as the tank becomes empty. I did once try mine out to see how many miles it would run after reaching  '0 miles', and it did les than two miles before running out, so the system works!
NN
In this case, its running the wrong program config, so will produce weird errors.
NaughtyNigel
  • Sedgefield, Co Durham
  • Naughty Nigel
« Reply #16 on: 03 June 2009, 16:25:43 »
NN
Why? It can only calculate expected range based on the present fuel level and the consumption over the past few miles. Ergo 'Range' prediction can go up or down.
NN
Why drive fast when you can drive fast in style? :)
« Reply #17 on: 03 June 2009, 16:36:21 »
NN
NN
Its the consumption bit that it gets horribly wrong, and it confuses the poor thing.
I only just got around to reprogramming mine (I swapped mine with Hotel21 a few weeks ago to prove a fault), my range was creeping up to 1300 miles from a tank. Not bad for a 3.0l auto ;D
« Reply #18 on: 03 June 2009, 16:51:13 »
...... my range was creeping up to 1300 miles from a tank. Not bad for a 3.0l auto ;D
Excellent! Can you do mine for me?  :y  :y  ;D  ;D
« Reply #19 on: 03 June 2009, 19:12:10 »
Of course ;D
NaughtyNigel
  • Naughty Nigel
« Reply #20 on: 03 June 2009, 23:11:10 »
NN
NN
You can do mine too!
What you are describing is clearly a fault. Mine works perfectly well with the numbers going up and down, which is what I was trying to explain. I can guarantee that not only does it go down to zero miles, it runs out of petrol soon afterwards too! :-[ :)
« Reply #21 on: 04 June 2009, 22:15:00 »
NN
NN
LOL, my old MID would do at least 18m beyond 0, but that was at 60mph down the M40 ::)
Not been brave enough to do another similar test ::)
