Author Topic: Lots of warning lights  (Read 2906 times)
Martin_1962
Re: Lots of warning lights
« Reply #15 on: 01 June 2009, 13:09:47 »
Or is it cat issue?
« Reply #16 on: 01 June 2009, 13:12:26 »
Or is it cat issue?
dont think so - that would be 420/430 and 170 codes
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #17 on: 01 June 2009, 13:31:50 »
Had this happen on my previous 2.0 Ecotec.
Turned out to be a duff earth lead from N/S/F of engine to battery negative terminal. Easily diagnosed by securely clamping a jump-lead from engine lifting-bracket to said terminal on battery.
Good luck mate!
Martin_1962
« Reply #18 on: 01 June 2009, 14:48:41 »
Battery has broken away from the battery clamp and is sliding around.
Some spilt acid :( :o
Will properly check tonight.
Had a mild acid burn - now OK
« Reply #19 on: 01 June 2009, 14:49:47 »
Fitted correctly?
Martin_1962
« Reply #20 on: 01 June 2009, 16:32:37 »
It was - one of those silly plastic mouldings on the side
Leak was the little window popped out - refitted
However I think the battery has lost the ability to be charged.
Will check tonight the voltage
« Reply #21 on: 01 June 2009, 17:23:53 »
My friends car's Ecu was damaged with Battery acid..
Change it asap..
Martin_1962
« Reply #22 on: 01 June 2009, 18:54:57 »
Not much acid lost, so topped it up.
COMPLETELY flat.
On charge now, I reckon either alternator or lead off.
Will check in the morning.
How much for an alternator?
« Reply #23 on: 01 June 2009, 18:56:43 »
COMPLETELY flat.
reckon alternator may have cooked the battery?
iirc, if you have a genuine TC card, there is an extra £10 off alternators til end of June...  ...I'll dig out my vouchers...
Martin_1962
« Reply #24 on: 01 June 2009, 19:10:51 »
COMPLETELY flat.
Mine is ABS
Will ask about recon ones, what is fitted to a 2.6?
Martin_1962
« Reply #25 on: 05 June 2009, 19:04:45 »
Well I have found out 0320 is Ignition/Distributor Engine Speed Input Circuit Malfunction
Possible crank sensor
