Author Topic: HELP Car only running on 3 cylinders  (Read 5860 times)
Martin_1962
« on: 05 June 2009, 18:44:37 »
HELP :'(
I need an expert to help me
Car is running on 3 cylinders and a replacement coil pack has not helped.
246 bank is misfiring 0300 0302 0304 0306
Occasionally it will rev high with a lot of throttle then it will struggle to idle.
It was running fine until 08:30 yesterday when it decided to get very noisy, then shut off then restarted on 3
I haven't even got the power to reverse out of my parking space.
I am completely out of ideas and I just don't know what to do.
Martin_1962
Re: HELP Car only running on 3 cylinders
« Reply #1 on: 05 June 2009, 18:46:48 »
Cam timing is fine.
KillerWatt
« Reply #2 on: 05 June 2009, 19:06:30 »
0300 = Multiple misfires detected
0302 = Cylinder 2 misfire
0304 = Cylinder 4 misfire
0306 = Cylinder 6 misfire
I've read a couple of other posts you've made about this issue and what you've done so far....next thing on the list has to be a compression test (especially as you said it got noisy before the fault appeared).
Martin_1962
« Reply #3 on: 05 June 2009, 19:07:23 »
I'll see if I can find it, any idea what pressure they should be?
KillerWatt
« Reply #4 on: 05 June 2009, 19:15:04 »
Off the top of my head, absolutely no idea at all Martin.
You definately want to see in excess of 100psi though, and I'd guess the true figure you want to see is probably around 130psi.
Do a test on cylinder number 1 as you know that works, and use that reading as a reference point.
Martin_1962
« Reply #5 on: 05 June 2009, 19:19:26 »
Will try tomorrow if not raining
Will look for pressure tester quite soon though
Martin_1962
« Reply #6 on: 05 June 2009, 20:35:34 »
1 150
2 very little max 80
3 140
4 eff all
5 150
6 can't get to plug
[size=24]HELP![/size]
KillerWatt
« Reply #7 on: 05 June 2009, 20:38:00 »
That tells you all you need to know then Martin.
Whatever has happened, you have lost compression on the 2,4,6 bank for some reason.
Next step is head off to have a looksee.
Martin_1962
« Reply #8 on: 05 June 2009, 20:43:34 »
What a b*gg*r
Looks like I need to lift 246 again
I am so peed off I could set fire to it.
Even thinking now of breaking it. :'(
« Reply #9 on: 05 June 2009, 21:29:05 »
What a b*gg*r
You say cam timing is fine?
You fitted the cam sprockets correctly?
« Reply #10 on: 05 June 2009, 21:48:26 »
What a b*gg*r
was this the bank where the gasket was put on  the wrong way round? If so have you replaced the gasket?
Martin_1962
« Reply #11 on: 05 June 2009, 22:02:51 »
What a b*gg*r
Yes they were still tight
Martin_1962
« Reply #12 on: 05 June 2009, 22:03:08 »
What a b*gg*r
Bad gasket is on 135
« Reply #13 on: 05 June 2009, 22:12:54 »
If theres no compression on that bank then I would have thought a load of bent valves.Timing slipped?,broken camshaft? :-/
candyman
  • Carrickfergus, N Ireland
« Reply #14 on: 05 June 2009, 22:14:02 »
check vour timing the old fashioned way before u lift your haed off. find tdc on each bank and watch the lifters as they rock. i had a daf engine once that craushed a woodruff key enough to put the timing out by 10deg.
ongoing projects- 99 3.0 elite est, 90 xr4x4 est twin turbo. expensive ornament- mz baghira supermoto. mk2 granada 2.8 gradualy disappearing in storage
Pages: [1] 2 3 4  All   Go Up
