Pages: 1 2 3 4 5 6 [7] 8   Go Down
Author Topic: viscous fan  (Read 16607 times)
Re: viscous fan
« Reply #90 on: 15 June 2009, 19:07:03 »
Coolant flush was done a few months ago, after I had the pump changed. How do you do an oil flush?
follow the instructions on the bottle ;)
was the coolant flushed withh a cleaning agent, such as forte cooling system flush?
chartz
  • Burgundy
Re: viscous fan
« Reply #91 on: 16 June 2009, 06:23:06 »
I will have to ask my mechanic!
osealy
  • dublin
Re: viscous fan
« Reply #92 on: 16 June 2009, 13:27:32 »
I tried all the recomendations , except oil flush.
Stat, pump, rad flush, leccy fans wired permanently on.
In the end I fitted a new rad , easy, 180 quid. It now sits at 95, 97 on inclines at 80mph. My viscous is fitted but doesn't engage.
Now  my steering pump banjo is leaking. The nut is a c##t to get at. >:( >:(
Re: viscous fan
« Reply #93 on: 16 June 2009, 18:56:08 »
Any cruising speed, and I mean ANY, mind would never go above 96C.  Never cruised it above 130mph.
Therefore, I'm guessing you still have an issue
chartz
  • Burgundy
Re: viscous fan
« Reply #94 on: 16 June 2009, 21:14:44 »
You mean the viscous clutch was always engaged like mine prior to radiator change ?
osealy
  • dublin
Re: viscous fan
« Reply #95 on: 17 June 2009, 09:44:45 »
No. It just spins uselessly, hot or cold. But I put it back anyway as it feathers along with the pump.
As TB says I may still have a prob but I dont like the idea of an oil flush. Still going strong at 167K.
chartz
  • Burgundy
Re: viscous fan
« Reply #96 on: 17 June 2009, 10:03:29 »
So it squeals continuously like mine then?
osealy
  • dublin
Re: viscous fan
« Reply #97 on: 17 June 2009, 14:46:25 »
No it's silent. It just doesn't work. I did use to drive a 94M auto est with a working viscous, it used to sound like a jet readying for take off. Temp always stayed below 90 even towing 1500kg
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
Re: viscous fan
« Reply #98 on: 17 June 2009, 17:00:08 »
My Viscous is permanently locked up so that I sound like a Eurofighter taking off
Is there a fix for locked Viscous's other than TBs anticipated suggestion of throwing them away?
Feint recollections of someone posting a remedy that involved heating them up
Re: viscous fan
« Reply #99 on: 17 June 2009, 18:37:23 »
renew, approx £70 iirc from bmw
Pitchfork
Re: viscous fan
« Reply #100 on: 17 June 2009, 18:58:07 »
The difficulty will be proving that it has been stored vertically
Re: viscous fan
« Reply #101 on: 17 June 2009, 18:59:34 »
exactly, so dont bother, its not needed.
chartz
  • Burgundy
Re: viscous fan
« Reply #102 on: 18 June 2009, 18:19:23 »
Well live in France... It is needed, in traffic jams or in mountainous areas in summer.
My brand new, BMW-sourced viscous clutch is already busted, after three days. Always engaged, although temp is normal. Even from cold.
As Americans would put it, bummer.
Pitchfork
Re: viscous fan
« Reply #103 on: 18 June 2009, 18:28:16 »
Probably because they stored it flat in the parts dept
chartz
  • Burgundy
Re: viscous fan
« Reply #104 on: 18 June 2009, 18:56:14 »
I'm on my fifth defective brand new one, all from BMW!
They tell me it's my fault, my car is rotten, they've never had a problem before.
Pages: 1 2 3 4 5 6 [7] 8   Go Up
