Author Topic: Broken Water Pump ??????  (Read 4507 times)
Re: Broken Water Pump ??????
« Reply #15 on: 19 June 2009, 13:23:14 »
The aux belt didnt fail and was actually still on the alternator, tensioner and water pump when it was taken off. I think in this case its unlikely to be that.
Agreed, yours was different, just explaining to Lizzie Zoom why waterpump does need replacing a set intervals.  You experience has shown another reason as well, though the end result was the same  :'(
« Reply #16 on: 19 June 2009, 13:49:22 »
Check the water pump pulley is not loose on the pump flange
1960darrenh
  • Kettering Northants
« Reply #17 on: 19 June 2009, 20:56:18 »
OMG great news!!!
The Omega has been fixed and is running sweet as a nut.
The timing belt HAD jumped 3 teeth. Luckily it didnt cause any damage. I'm well chuffed.
Just shows how tough these engines are!
« Last Edit: 20 June 2009, 10:00:48 by 1960darrenh »
NiallyV6CDX
  • County Down
« Reply #18 on: 19 June 2009, 21:45:21 »
Hurrah!!!! :y ;D
Ian_D
  • York
« Reply #19 on: 20 June 2009, 09:53:52 »
Very lucky!  :y
[size=12]
