Author Topic: MV6 Wont take full throttle+ idling high  (Read 1910 times)
Omega6pot
  • Lisburn N.Ireland
  • Less Traction more action
    • 3.0 MV6 + 3.2 V6 Special
« on: 21 June 2009, 12:56:47 »
Hi, my MV6 has recently decided to not accept full throttle and is idling quite high (1100 RPM). the car drives fine until full throttle when it drops all power and makes a loud induction noise, if full throttle isnt released, the revs drop until it stalls, any ideas anyone?
cheers AL
Working on my 30th Omega 3.2 V6 Special
Re: MV6 Wont take full throttle+ idling high
« Reply #1 on: 21 June 2009, 13:00:34 »
Check for air leaks  :y
Omega man 2
« Reply #2 on: 21 June 2009, 13:00:52 »
Sounds like a vacum leak. Can cause high idling and could stall at high revs if the MAF isn't reading all the air going into the engine
Omega man 2
« Reply #3 on: 21 June 2009, 13:01:12 »
SNAP :D
« Reply #4 on: 21 June 2009, 13:01:44 »
SNAP :D
Yup  ;D
Omega6pot
  • Lisburn N.Ireland
« Reply #5 on: 21 June 2009, 13:04:58 »
ive taken the inlet off and clean all gaskets and checked the pipes going in, eveything seems good, it had a fault code about a knock sensor but when i cleared it the code didnt reappear yet the symptoms continue
candyman
  • Carrickfergus, N Ireland
« Reply #6 on: 21 June 2009, 13:53:49 »
did it just start this while driving or when you first started up?
ongoing projects- 99 3.0 elite est, 90 xr4x4 est twin turbo. expensive ornament- mz baghira supermoto. mk2 granada 2.8 gradualy disappearing in storage
Omega6pot
  • Lisburn N.Ireland
« Reply #7 on: 21 June 2009, 15:40:00 »
done it since the head gaskets where done, i think i have found the problem, think the knock sensor wires have been allowed to touch the manifold and so are a little burnt, hoping that sorting the wiring will have it sussed
« Last Edit: 21 June 2009, 15:40:20 by Omega6ot »
candyman
« Reply #8 on: 21 June 2009, 15:46:28 »
oops! were only human so all make mistakes, especially me!
markey mark
  • SLady bitshorpe north lincs
« Reply #9 on: 21 June 2009, 15:47:39 »
paper clip it and post codes bud ! if wire has been on manifold it will need changing  :y
