Author Topic: Crak seal leak  (Read 4727 times)
The Cambelt Kid
  • Derby
Re: Crak seal leak
« Reply #15 on: 21 June 2009, 20:24:26 »
Finally installed the crank seal today.  After a thorough cleanup i lubricated the new seal and then drove it in with a special tool on loan from Mark.  Once the tool had done its work, i used a large socket to drive it in until flush.
Now onto the good stuff - re-installation of the crank bolt! My dad and i whipped up a wooden wedge to make this task a tad easier, see pic attached:
With the wooden tools in place we found it very easy to torque up the crank bolt, far easier than i first though as i was expecting it to be a royal pain in the rectum.
Next step was the timing belt and as most of you may know this isn't my party trick  :'(
Anyhow, as i am well versed in timing belt installation i managed to install and time up the belt in good time. however i do have one burning question:
As i am installing a used belt, can anyone advise on which marking i should use on the tension pulley?  I have already lined it up with the marking which i made proir to removal, so the belt is tensioned up exactly as it was before.  Woould this be a good move?
Please let me know your thoughts.
Regards
[size=18]Project LP6 has landed![/size]
[size=12]DIY LPG now finally complete!! Whoo hoo.[/size]
Page created in 0.037 seconds with 16 queries.
