Author Topic: Found the coolant leak :(  (Read 3180 times)
Abiton
Re: Found the coolant leak :(
« Reply #15 on: 27 June 2009, 19:28:45 »
Thanks deviator, I missed this helpful reply.
I have got new genuine everything, except tensioner which I'm going to gamble on, and water pump which was done 2 years ago.
It's not a V6, it's a humble 2.0, so a bit easier, and only one HG.  :)
I was correct in my diagnosis at least - took the head into work on Friday and had a guy (cheers Mike!) at the next-door Porsche garage have a look/measure; and he confirmed that coolant had got into pot 4, but the head was fine to stick back on with no skim.  :)
Head's back on now, 'just' got cams to go back in, (new) timing belt to go on and then all the stuff I've had to disconnect/remove to replace.
Any words of wisdom w.r.t. cam belt would be much appreciated just now (one of tomorrow's scariest tasks).  Haynes confuses me a tad, I have to be honest.  Guess I'll just keep tweaking it 'til it seems spot-on after the obligatory 2 smooth turns of the crank.
Wish me luck please folks.  :y
Abiton
« Reply #16 on: 01 July 2009, 17:50:22 »
Well it's done, and it's all looking good.  :)
Gasket was amazingly intact, with just a small area of the fire-ring on pot 4 showing the passage of coolant past it from the big central channel at the rear of the engine.
The engine's now running better than it ever has during our 3 years of ownership.  :)
Advice to fellow 4-pot owners:  If you're losing coolant and you can't find where it's going, do yourself a favour before the heater matrix and radiator give up; get it checked for 'zorst fumes in the coolant, or simply shine a torch down the spark plug holes looking for wetness that ain't oil.  :y
Parts guy at Vx reckoned I'd've paid £800 and upward if they'd done this job, so thanks to TB and the forum generally for giving me the confidence to have a go myself.  ;)
NaughtyNigel
  • Sedgefield, Co Durham
  • Naughty Nigel
« Reply #17 on: 02 July 2009, 11:01:25 »
That's great news. I hope it keeps running well for you. We had a new head gasket fitted to our Astra a year or two ago, and it has run fine ever since. (Cost £450 at a local indy).
I am still trying to psyche myself up to tackle the head gasket on my 2.5 V6.  :o
I know I can do it, and I know it will be worth it, but its a lot of work to do without proper facilities.  :-/
NN
Why drive fast when you can drive fast in style? :)
