Author Topic: Engine will not start !!!!  (Read 3611 times)
MutantCav
  • Gainsborough
Re: Engine will not start !!!!
« Reply #15 on: 15 July 2009, 23:12:12 »
Yep as Gary says :y
Richard A
  • Aldridge, West Midlands
« Reply #16 on: 15 July 2009, 23:31:58 »
Current 'crank sensor ' fitted 9th May 2007 - 117,500 miles. So yes it is 40,000 miles and 2 years old, will check No 20 fuel relay first then replace 'crank sensor'.
many thanks
regards
richard a
richard a
Richard A
« Reply #17 on: 16 July 2009, 17:45:57 »
Engine will start  :y
£51.47 for a new Crank Sensor, problem sorted.
Expected them last longer than two years, the original one lasted 9 years.
Many thanks for everyones help, great forum.
regards
richard a
richard a
jonnycool
  • Merthyr Tydfil, S. Wales
  • We shag 'em, you eat 'em
« Reply #18 on: 16 July 2009, 17:55:53 »
Bloody crank sensors eh? We should all keep spares - seems like 99% of all problems with Omegas start with the crank sensor
SP_3.2
  • Leicester
    • drives A6 allroad 3.0tdi
« Reply #19 on: 16 July 2009, 18:00:27 »
That,s good news :y :y also thank you for the tip afew months ago about how to get the seat belts clean and carpets in the car ...been using the1001 shampo product and it has worked great  :y :y. Like new  untill my sons sticky fingers get to them again ;D ;D
Steve
MutantCav
  • Gainsborough
« Reply #20 on: 16 July 2009, 18:01:18 »
Just to be sure, did you get a gen Vaux one and was it routed away from heat sources as much as possible?? :y
Richard A
« Reply #21 on: 16 July 2009, 18:21:37 »
Yes from a Vauxhall dealer, who are ok for spares and yes away from the exhaust. Dead easy to change this time as the connector was insight, not at the back of the engine. Out of interest both of the GM ones I have bought were 'Made in France'.
Steve '1001' every time  :y
regards
richard a
richard a
MutantCav
  • Gainsborough
« Reply #22 on: 16 July 2009, 18:35:30 »
Good good :y And away from the oil cooler pipes that Vauxhall place them between when fitted in the factory???? :y
« Last Edit: 16 July 2009, 18:36:10 by ShieldOfSteel »
