Author Topic: ABS ECU  (Read 3241 times)
johnnycboy
  • Colchester
Re: ABS ECU
« Reply #15 on: 17 July 2009, 16:35:51 »
Just an update - I've fitted ABS ECU from a crappy scrappy only to find that the one I've put on as ESP (and not the telepathy one) comes up with identifier 1x114,  anyhow I still have TC light on dash and a redlining rev counter, but what I find strange is my LPG will not work now.  I know the varient needs programming and am awaiting another ECU courtesy of an oof member, what as baffled me though is why the LPG has stopped working, will not even communicate with software - Does the ABS ECU have all connections running though it which control the engine ECU.  Any information appreciated
Just spoke to Lazydocker and we have worked out why no gas.  Due RPM red lining at 7K the RPM signal to Gas is breaked.  Hopefully remedied when next ECU installed. :-/
« Last Edit: 17 July 2009, 17:35:02 by johnnycboy »
Re: ABS ECU
« Reply #16 on: 17 July 2009, 17:58:26 »
Otherwise I know what I'll be doing on my next set of days off ::) ::) ;D ;D
johnnycboy
  • Colchester
Re: ABS ECU
« Reply #17 on: 17 July 2009, 18:16:36 »
You can still help me fit the ECU if you like :P
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
Re: ABS ECU
« Reply #18 on: 18 July 2009, 09:13:55 »
really easy to get off when you have no engine or front end on the car ;D ;D ;D ;D
MartinP
  • Dudley
    • BMW 320D
Re: ABS ECU
« Reply #19 on: 18 July 2009, 19:44:11 »
