Author Topic: heated front seat  (Read 1949 times)
x.ray
  • walsall west mids
heated front seat
« on: 18 July 2009, 12:31:35 »
good morning all.
as you are all aware they do not do a haynes manual for an x reg 2.2.
therefore how do i check why my heated front seat is not working.
the passengers works fine?
cheers :'(
Agemo
  • Cleethorpes
  • Insignia
Re: heated front seat
« Reply #1 on: 18 July 2009, 15:14:24 »
One fuse covers both, so if the passenger one is OK, you should look at the connection under the seat. It is possible for the elements to fail, but not likely both have failed in the same seat.  ::)
« Last Edit: 18 July 2009, 15:15:06 by Agemo »
« Reply #2 on: 18 July 2009, 15:36:54 »
Its more than likely the elements but they are quite easy to replace if your seats are cloth :)
unlucky mark mv6
  • tipton,west mids
« Reply #3 on: 18 July 2009, 15:44:50 »
Ive heard the sires break on these,how do you sort that out on a leather,is it a complete strip down or what? :-/
« Reply #4 on: 18 July 2009, 15:46:19 »
The elements are sown into the leather seats so I would just push a new element between the leather and seat foam, it might take a bit longer to heat up though
unlucky mark mv6
  • tipton,west mids
« Reply #5 on: 18 July 2009, 15:50:38 »
Would really like to repair the old one,i have heard its possible if its just the sires whatever they are,i think they are the wires that run down the back or something,anyone done this as i need to fix because it irritates me knowing something doesent work on my car. ::)
Agemo
  • Cleethorpes
  • Insignia
« Reply #6 on: 18 July 2009, 16:11:09 »
Both elements going at the same time? Bit of of a coincidence but perhaps it could be.  ::)
unlucky mark mv6
  • tipton,west mids
« Reply #7 on: 18 July 2009, 16:13:34 »
Got to be the elements mate,checked the connecter at seat and got power. :-/
« Reply #8 on: 19 July 2009, 10:00:41 »
The base & lower back heating elements are wired up in series with other, so if one fails, you've loose both.  :y
« Last Edit: 19 July 2009, 10:00:53 by Andy_B »
Agemo
  • Cleethorpes
  • Insignia
« Reply #9 on: 19 July 2009, 13:43:27 »
Ahhhh, nice to know that, thanks.  :y
Page created in 0.035 seconds with 20 queries.
