Author Topic: Oil Warning Light Flickering When Idling 3.2 v6  (Read 3660 times)
Re: Oil Warning Light Flickering When Idling 3.2 v6
« Reply #15 on: 21 July 2009, 13:13:14 »
Hmm. Oil leak could be oil pressure sensor FUBAR, which might explain the oil light.
Check that the coolant hasn't been diluting the oil though (oil cooler / HG?).
Jim
  • Glasgow
    • Irmscher 3.2 V6 Elite
    • My Vauxhall Omega's
« Reply #16 on: 21 July 2009, 13:20:42 »
is the oil presure sensor located in the area of the leak.
If you go back I've just added another picture and there is no mayo in the oil filler cap
« Reply #17 on: 21 July 2009, 14:44:30 »
Oil pressure sensor is on the driver's side, front of the engine below the alternator. You should see it poking out just above that corner of the sump with a wiring connector attached to it.
Jim
  • Glasgow
« Reply #18 on: 21 July 2009, 18:28:14 »
Yep, I know where you mean I've seen it on another omega, It's pouring down here at the moment I'II have a look then it stops :y
