Pages: 1 [2] 3  All   Go Down
Author Topic: HELP!!!!  (Read 5974 times)
KillerWatt
Re: HELP!!!!
« Reply #15 on: 22 July 2009, 16:03:35 »
I'd settle for welding a small patch over the hole myself (seam welded obviously).
By the time you removed it to weld you would have fitted another/new sump ..... unless you're going to weld it with oil in there!  :-?  :-?
If it's as small a leak as the OP leads us to believe, then there would be nothing wrong with welding a small plate over the top of the hole while the sump is in situ and filled (unlike the epoxy resin solution, which really needs to be "clean" while it cures).
Re: HELP!!!!
« Reply #16 on: 22 July 2009, 16:08:14 »
It's easier to re-apply ythe epoxy putty if need be than put the the fire out in the engine bay after you set fire to it!  ;D
portomega
  • Port Talbot, S. Wales
Re: HELP!!!!
« Reply #17 on: 23 July 2009, 12:10:10 »
Right my co-worker last night put some sealant over the hole but im not sure it designed for things like this, as the sump gets very hot and im guessing it will just cause the sealant to come loose  ::) but its a quick fix for now till i got the time to get it sorted.
Haynes never did a manual for the Omega did they? i got told that the 2.2 from the vectra is the same engine and you can use the manual for them on the omega, is that right? :question
mantagte
  • great yarmouth
    • omega bmw maverick
Re: HELP!!!!
« Reply #18 on: 23 July 2009, 12:31:35 »
yes haynes did do a manual for the omega goes upto a t reg 1999 but the mechanics are more or less the same
portomega
Re: HELP!!!!
« Reply #19 on: 23 July 2009, 12:32:44 »
mines a 2004 though :( so the omega manuals wont apply to mine
mantagte
  • great yarmouth
Re: HELP!!!!
« Reply #20 on: 23 July 2009, 12:35:56 »
as said the mechanical bits are more or less the same throughout from 1994-2004
bob.dent
  • Hertfordshire
  • Drives better than an Omega
    • Mondeo 2.0TDCI Estate
Re: HELP!!!!
« Reply #21 on: 23 July 2009, 12:46:30 »
Try these UK spare parts locator sites.
http://247spares.co.uk/
http://www.partsgateway.co.uk/
portomega
Re: HELP!!!!
« Reply #22 on: 23 July 2009, 12:57:24 »
cheers  :y will give them a look
Re: HELP!!!!
« Reply #23 on: 23 July 2009, 12:57:56 »
IIRC the sump is in 2 parts, if its the part with the sump plug i'm sure you can remove it with the engine in situ
portomega
Re: HELP!!!!
« Reply #24 on: 23 July 2009, 13:00:54 »
Yeah i think its the part of the sump with the plug , the rust spot it right at the front of the sump, i think the garage yesturday said the sump is in 2 pieces the front streel and the back aluminium.
going crazy
  • Middlesex
Re: HELP!!!!
« Reply #25 on: 23 July 2009, 22:36:05 »
you might want to try this (quicksteel) another epoxy putty
http://www.ksealit.com/quiksteel-6-p.asp
portomega
Re: HELP!!!!
« Reply #26 on: 25 July 2009, 13:17:52 »
Right im just on my way to halfords to buy some of this epoxy putty that you guys have recommended as a tempory fix for the sump leak, but while on their site i was treatments for rust , i was just wondering do you think this stuff would be worth adding first before the putty? just to help seal up the hole :question
portomega
portomega
jonathanh
  • coventry
Re: HELP!!!!
« Reply #29 on: 25 July 2009, 15:52:03 »
I would'nt bother with that for a temp fix - it may get you an extra month or so - no idea
you have a few rust spots on the sump but it does not mean you need to replace it.  the spot that is leaking, it is on a flat part of the sump?  If so I'd suggest a good, drop the sum as best you can and fit a bolt through two flat washers, one inside and one out.  tighten up and you are there.  As to the others,  i'd clean down to bare metal, then pain with primer, then two coats of hammerite paint  who cares what it looks like if it doesn't leak!
Pages: 1 [2] 3  All   Go Up
