Author Topic: Tyre Pressures  (Read 3269 times)
Ratty
  • Coventry
    • '99 2.5 CDX Mini-FL Est
Tyre Pressures
« on: 01 August 2009, 16:23:16 »
Hi,
My Miggy Estate has 205/50R16 tyres on, does anybody know what pressure these should run at with normal loading.
Thanks
John
Ghost
  • Seaham, North East england
    • 2.6 V6 CDX Estate
Re: Tyre Pressures
« Reply #1 on: 01 August 2009, 16:28:45 »
I have 205/65R15 on mine and I keep them at 2.5Bar
He who brakes Looses
To old to die young
slavi13
Re: Tyre Pressures
« Reply #2 on: 01 August 2009, 16:46:11 »
It depeds of the load of the car.If it is used for daily commute 2.2 bars(30psi) is enght.If you carry laguage it needs to be min 2.5 (35psi).
Ratty
  • Coventry
Re: Tyre Pressures
« Reply #3 on: 01 August 2009, 16:54:28 »
loading is only me, a few tools in the back and the odd teenager now and again, so if i put 30psi all round would that be ok for the size of tyre and load?
« Last Edit: 01 August 2009, 16:54:55 by ratsalad »
John
Ghost
    • 2.6 V6 CDX Estate
Re: Tyre Pressures
« Reply #4 on: 01 August 2009, 16:59:22 »
It should be ok, I do a bit of wieght in mine (the wifes shopping Lol) so I have them a bit higher.
Its also recommended for a sporty driving style.
« Last Edit: 01 August 2009, 17:00:43 by acdcdave »
To old to die young
joshwyatt
  • Oxford
Re: Tyre Pressures
« Reply #5 on: 01 August 2009, 17:02:14 »
Do you have the vehicle manual and service books etc in the leather wallet? All the correct tyre pressures are in there for each tyre size. For loaded, unloaded and continuous speeds of over 100 mph.
Ratty
  • Coventry
Re: Tyre Pressures
« Reply #6 on: 01 August 2009, 17:02:20 »
cheers fella, that'll do me  :y
John
Ratty
  • Coventry
Re: Tyre Pressures
« Reply #7 on: 03 August 2009, 14:43:15 »
Just a quick update:
Checked the tyre pressures for the first time this morning since picking the car up last week, O/S front 38psi N/S front 37psi both rears 34psi  :o :o
adjusted to 30psi all round and seems to drive a wee bit better  :y
John
Ratty
  • Coventry
Re: Tyre Pressures
« Reply #8 on: 03 August 2009, 14:46:26 »
Sorry, I missed this post, no the handbook along with the passcard and wheel key were stolen by a previous viewer of the vehicle, I have bought a new set of handbooks for it now though which should be here in a few days.
« Last Edit: 03 August 2009, 14:47:28 by ratsalad »
John
Re: Tyre Pressures
« Reply #9 on: 03 August 2009, 15:10:56 »
Ratty
  • Coventry
Re: Tyre Pressures
« Reply #10 on: 03 August 2009, 15:48:16 »
have a look at this
http://www.omegaowners.com/forum/YaBB.pl?num=1184621237/all
If you're referring to the flyer info my tyre isn't listed on there or any other tyre pressure info for the Omega hence the reason of this thread mine are 205/50 R16
Thanks
« Last Edit: 03 August 2009, 15:49:32 by ratsalad »
John
JohnM
  • Newark on Trent
    • 2.5M Estate
Re: Tyre Pressures
« Reply #11 on: 03 August 2009, 20:57:44 »
I thought the consensus around here was 33psi all round (for light loading).
It's air, not oil, feel free to debate.
Ratty
  • Coventry
Re: Tyre Pressures
« Reply #12 on: 03 August 2009, 21:46:21 »
Okay, now you've thrown doubt back into it  :P Help, can someone tell me what it should be? 33psi or 30psi for 205/50 R16   :)
John
Re: Tyre Pressures
« Reply #13 on: 04 August 2009, 00:32:21 »
205/50/16?
Are they standard or a size you upgraded to from 15"
Ratty
  • Coventry
Re: Tyre Pressures
« Reply #14 on: 04 August 2009, 05:10:40 »
I don't know, I only bought the car last week, it was what was already fitted, the spare is the same size too which doesn't look like it has been used for a while judging by how dry and dusty it is. I've seen other mini-facelift Miggys with 16s on but they all seem to use the 225/55 variant.
Another symptom that does seem to point to the fact that these aren't OE sized boots is that the speedo seems to be a long way out, when my satnav is showing 30 the speedo shows about 38, this is fairly constant throughout the range I.E. 70 on the satnav = 78 on the speedo ETC. all previous cars I've had were only 2 - 3 mph out.
John
Page created in 0.112 seconds with 20 queries.
