Author Topic: Part Numbers, prices and torque value  (Read 2277 times)
Toby
  • Ringwood, Hampshire
« on: 03 August 2009, 11:45:05 »
Does anyone have access to part numbers for the following:
Front pipe/intermediate pipe gasket
Manifold/front pipe gasket
Radio Cage CCRT700
with prices for the above and the following:
90511451
90411826
90501652
90501653
9118135
90485251
Going to pop to VX to get that and the cam cover gaskets
Also need a torque value for the lambda sensors.
Thanks  :y
Toby
Re: Part Numbers, prices and torque value
« Reply #1 on: 03 August 2009, 21:12:04 »
Found the torque value.
Anyone help with numbers and prices? Don't want to go to VX to find I get bent over the counter so to speak.
Toby
« Reply #2 on: 07 August 2009, 21:06:11 »
Nope?
Anyone got a price for a new set of clocks from VX?
« Reply #3 on: 07 August 2009, 21:08:36 »
Nope?
Have you tried contacting the breakers on here. Look in the car parts section
Pete Elite
  • Uxbridge, Middlesex
« Reply #4 on: 07 August 2009, 21:17:46 »
Nope?
  Have they got the Blue circuit board and if so i may have a set available if the set i just purchased(second hand in very good condition with 106000 mls. on)don't work on mine which have has Green circuit board :-/.
Toby
« Reply #5 on: 07 August 2009, 23:10:32 »
The plastic one on the back is blue yes, the inner board is green.
I just wondered about a new one as I'm confusing myself with PMs about many different ones from different people  :D
Just thought a new one might be easier and VX may have the proper equipment to adjust the mileage.
Pete Elite
« Reply #6 on: 07 August 2009, 23:58:48 »
Yes Toby the Blue bit on the rear is the same as mine, as for buying a new one i would have thought it would be pretty expensive :o.
  Does it really matter about the mileage, if you want to sell at some time just let the prospective buyer know you changed the clocks and the mileage on the new and old ones :).
Toby
« Reply #7 on: 08 August 2009, 00:05:07 »
Think the numbers need to match though. Need to pull my clocks out to check. Got a couple of people waiting on numbers, will let you know Pete.
I know, thats the easiest route! I can't help but being pedantic though.  ::) However, I may just try to get as close as possible and leave it. Yes, I expect they are expensive, would be interesting to find out  :o I am after all planning on changing cars around March. I just cannot decide what I want, thinking either a 3.2 Mig or something with a V8 but even then, not sure what V8
« Last Edit: 08 August 2009, 00:05:44 by Toby »
Pete Elite
« Reply #8 on: 08 August 2009, 00:38:56 »
I know what you mean Toby, I'm a fuss arse as well ;D.
 The # on the set I've got is:  90564492PR   if that helps :).
 PS.   Don't know if i can use these on mine as mine has the green back so will have to find out and let you know but if they don't then your welcome to have them for what i paid for them £15 inc. P&P :y
andyc
  • Norfolk
« Reply #9 on: 08 August 2009, 09:18:49 »
Front pipe/intermediate pipe gasket  don't have a gasket
Manifold/front pipe gasket  90499289 £5.61
Radio Cage CCRT700 9146050 £4.86
90511451 £24.89
90411826 £0.15
90501652 £11.07
90501653 £9.37
9118135   £10.38
90485251 £3.39
Thanks  :y
« Last Edit: 08 August 2009, 09:21:45 by andyc »
Thetford. Norfolk
