Author Topic: A good idea gone badly wrong!  (Read 1681 times)
portomega
  • Port Talbot, S. Wales
« on: 17 August 2009, 01:30:21 »
Some complete git keyed my car on Saturday night , from the headlight right down to the brakelight on the drivers side, the scratches were deepest on the rear door and just above petrol filler cap , scratch removal paste got rid of the lighter ones but not these areas, so i decided get some spray paint from Halfords ( first mistake) and try spraying over the scratch ( second mistake)  ::) didnt go well! you can see exactly where i sprayed and it sticks out like a sore thumb, it looks terrible  :( :-/ Anyone got any idea how i maybe blend it in better , are there any products for this kind of cock up? ( i tried removing it with the scratch removing paste but it made it worse! )or is there anything that will maybe remove this paint? or what you rekon someone would charge to re-spray a door?  :-[ :-[
3.2 manual
  • nr yeovil, somerset
  • the great thread ender! whoops
Re: A good idea gone badly wrong!
« Reply #1 on: 17 August 2009, 03:46:45 »
with very fine wet and dry(1200+), used wet wait about a week then gently rub off the new paint, being carefull to only just remove it and not go throught the laqour if its metalic or paint if it aint. go to vauxhall and get the proper colour touch up pens, put masking tape about 1/2 mm each side of the scratch and touch it up along the length if your car is a straight colour do a few coats till its ever so slight above level, wait a week, but you can take the tape off. then with fine wet and dry, used wet, gently rub back the raised line till level and teecut and wax back till nice. it may not be perfect but can be almost un-noticable if done carefully. and lesson learned dont buy paint from said shop, im sure its mixed after a morning on the thinners. metallic is a bit more difficult but same sort of idea but cover with colour till just below level and use laqour to get just above level. the closer you can get the tape to the scratch i.e the thinner the bit you paint the less noticable it will be. wait a bit other people may have better ideas but ive done it like this in the past and after a while and a few cuts and polishes forgot where it was!
« Last Edit: 17 August 2009, 04:01:11 by lovelectricity »
oh bugger, i thought that was a bit of wind!!!
NiallyV6CDX
  • County Down
« Reply #2 on: 17 August 2009, 12:13:54 »
Sounds like good advice, and NEVER EVER EVER buy paint from Halfords!!! ::)
P.S to get the stuff you have just sprayed on off, a gentle bit of T-cutting might do the trick.
portomega
« Reply #3 on: 17 August 2009, 14:31:18 »
thanks for the advice folks, and yeah ive learned my lesson lol never buy paint from halfords, it says "star silver" on the can but when it hits the car it dont look the same at all  ::)
« Reply #4 on: 17 August 2009, 14:40:51 »
IIRC Vauxhall did 3 shades of Star Silver
Richard A
  • Aldridge, West Midlands
« Reply #5 on: 17 August 2009, 14:41:38 »
Take the colour code from the car as there were several 'star silvers' (the same for other colours) also as well as the pens Vauxhall do very good spray tins of colour and lacquer at good prices.
regards
richard a
richard a
portomega
« Reply #6 on: 17 August 2009, 14:42:55 »
3 shades? see it dont say that on the Halfords paint lists  ::) if i dont blend it in or removed what ive done , has anyone ever had a door re-sprayed and how much was it? or is it just easier and cheaper to get another door?
andyc
  • Norfolk
« Reply #7 on: 17 August 2009, 14:45:03 »
There are three different Star Silver's and they are not all the same.
Get the paint code of the chassis plate an pop in your local dealer as thet will need to know which one you have.
Be warden though silver is one of the worst colours to match
If not you could try companies like Chips away
Cheers
Andy
Thetford. Norfolk
