Author Topic: Instrument panel printed circuit board?  (Read 1540 times)
Jan Suhr
  • Nyköping, Sweden
    • 2 Omega Caravans 3.2 V6
« on: 17 August 2009, 16:23:18 »
On my 2001 omega the printed circuitboard on the backside of the intstrument panel has been damaged. I had it removed a while ago and the circuits for the battery lamp is broken.
I wonder if the printed circuitboard/foil is available as a sparepart. It looks like it is replaceable.
Thanks
Jan
Jan Suhr
Stockholm, Sweden
www.protouring.se
I_want_an_Omega
Re: Instrument panel printed circuit board?
« Reply #1 on: 18 August 2009, 18:04:20 »
Send me a PM with all the numbers from the board.
I have a number of instrument panels and would be quite happy to supply you with the circuit board if required.
Regards .......... Rob
« Reply #2 on: 18 August 2009, 18:58:07 »
The 'board' is not available seperately.
If you get replacement instruments, make sure its right for your year of car, and your engine (varies).
If you manage to locate a new 'board', it may well need programming/configuring via Tech2
Abiton
« Reply #3 on: 18 August 2009, 19:07:03 »
If it's just a copper track or two that has broken, it's quite straightforward to repair with thin wire and a (small, low-power) soldering iron. Old-fashioned lead-based solder is probably better as its melting point is a bit lower than 'modern' stuff.
Just scrape down to bare shiny copper either side of the break(s) and link across with some fine wire.
A little of the plastic may melt, but not too much if you're quick.
