Author Topic: Getting more power  (Read 4508 times)
stemon
Re: Getting more power
« Reply #15 on: 17 August 2009, 22:38:19 »
im also interested in decatting but no one seems to have experience in it on the 3.0 omega.
there must be someone?
NiallyV6CDX
  • County Down
« Reply #16 on: 18 August 2009, 01:19:16 »
Not true at all. De catting will deffinately give you more power, as will removing the centre silencer boxes.
There is much debate about whether sports air filters are any goon on the omega, so its up to the individual to weigh up the pros and cons but with the exhaust work done it might be helpful. Then a remap afterward.
As for engines that would fit, I hear someone has stuck a 3.0 turbo straight 6 from a toyota supra in :D
A BMW straight 6 with a turbo is always an option (won't cause space and cooling issues). V8s I dont know much about, but the chevy small block 5.7 goes in supposedly, and is also very tuneable.
« Reply #17 on: 18 August 2009, 01:45:56 »
iirc one of our American friends has de cated a v6. Not entirely sure of his online name, CateraV6 or something like, maybe? Probably got that totally wrong, but there are some post of his in the Gallery, you could pm him.
DOC23
« Reply #18 on: 21 August 2009, 15:39:37 »
Bump any more advice on de-catting??
« Reply #19 on: 21 August 2009, 23:41:04 »
I tried de-catting , you really loose the low end torque..
you can play with heads.
playing with compression ratio will give better result together with bigger inlets..
also ecu remap is a good idea..
and I must add v6 cooling system is not adequate for serious mods..
so if you are after serious power increase go for another engine which will be more economical than modding x30xe .. :-/
« Last Edit: 21 August 2009, 23:42:35 by cem_devecioglu »
