Author Topic: ebay key repair advice  (Read 3896 times)
Charlies Dad
« on: 21 August 2009, 21:12:47 »
220286465955
i have a knackered key (have to put the key in the door to open) if i by one of the above would i need tech 2 to reprogramme it.
will it even work ? ?
Re: ebay key repair advice
« Reply #1 on: 21 August 2009, 21:35:06 »
Try PMing Martin Imber here, he does key repairs
Charlies Dad
« Reply #2 on: 21 August 2009, 22:01:05 »
i only have one key though thats the problem i have
« Reply #3 on: 21 August 2009, 22:02:00 »
Any 'New' key (as in new to the car) will need programming to the car
STMO999
« Reply #4 on: 21 August 2009, 22:03:00 »
If the one you've got works for now, it would be better to bite the bullet and pay for one from Vx. Expensive but you know it will work.
« Reply #5 on: 21 August 2009, 22:10:12 »
Its only a repair kit - "this is not a complete remote!
HERE WE HAVE A REMOTE ALARM KEY REPAIR KIT AND BATTERY.
THIS KIT CONTAINS A BRAND NEW BUTTON PAD AND BATTERY ONLY."
Wouldn't have thought you'd need a tech2 in this case.
Charlies Dad
« Reply #6 on: 21 August 2009, 22:42:26 »
so would i need to do the ignition trick to pair the two back together
« Reply #7 on: 21 August 2009, 22:43:24 »
Would have thought so mate  :y
Charlies Dad
« Reply #8 on: 21 August 2009, 22:48:57 »
worth a go then ?
« Reply #9 on: 21 August 2009, 22:56:32 »
worth a go then ?
Depends what's wrong with your existing one.
If you're currently opening it with the key, why not separate the key and remote, send the remote to Martin and use the key section in the meanwhile. Be very careful not to lose the transponder chip out of it!
The usual failure is the buttons on the PCB and they're not included in this kit.
Charlies Dad
« Reply #10 on: 21 August 2009, 23:01:54 »
worth a go then ?
kevin i never thought of that - so so simple. i will pm him now does anyone know what he charges ?
« Reply #11 on: 21 August 2009, 23:26:26 »
It's about £7 a key I think .. :)
Charlies Dad
« Reply #12 on: 21 August 2009, 23:27:16 »
cool have pm'ed him, see what he says
alexandjen
  • Sittingbourne, Kent
  • The Silver Surfer
« Reply #13 on: 23 August 2009, 19:27:35 »
It was £10 inc. recorded mail for return of repaired fob when he did mine :y :y
Trade club card holder
Code scanner available
bluehawk
« Reply #14 on: 23 August 2009, 20:57:12 »
worth a go then ?
Just Remmber to stick some take over the transponder chip to stop it falling out of the key and getting lost other wise you could end up with a bigger problem. ;)
Page created in 0.032 seconds with 20 queries.
