Author Topic: Transmission Bung missing?  (Read 1270 times)
AlexMitton.co.uk
  • Liverpool, UK
« on: 27 August 2009, 05:53:20 »
Morning OOF,
My Omega is leaking Automatic Transmission Fluid due to a Bung/Seal which has gone missing?
Does anybody know the proper name for it? Because I cant find it anywhere?
Note to Mod: Note sure to where to post this.
Thanks alot,
Alex
[size=12]
2000 - Omega CDX - 2.5 V6 - Automatic - Saloon (Click here for info.)
[/size]
unlucky alf
  • worksop, notts
Re: Transmission Bung missing?
« Reply #1 on: 27 August 2009, 11:53:20 »
the best thing to do is first check the filler hole has got its plug in [on edge of large sump drivers side], if thats in situ then id give the g/box a good clean, top it up [follow "how to guide"] then take it for a run & see where the leak is coming from. :y
« Reply #2 on: 27 August 2009, 12:25:26 »
If the rubber bung you mean is the one underneath on the bell housing, then atf leakage from here likely caused by g/box front seal knackered - a gearbox out job :(
AlexMitton.co.uk
  • Liverpool, UK
« Reply #3 on: 28 August 2009, 22:38:52 »
I've had it up on the lift in my mates garage.
I can see a whole where something goes, and oil inside it.
[size=12]
[/size]
  • Auckland
    • Mazda MPV
« Reply #4 on: 28 August 2009, 22:47:26 »
A photo would help to identify this mysterious bung (or a clearer description)
« Reply #5 on: 28 August 2009, 22:48:55 »
I'm with dbug on this one.  ;)
AlexMitton.co.uk
  • Liverpool, UK
« Reply #6 on: 28 August 2009, 22:56:03 »
OK, I'll get it back on the lift and take a photo.
Cheers
[size=12]
[/size]
« Reply #7 on: 29 August 2009, 16:47:26 »
Thanx mate - been there, done it!!  Put new seal on, still leaked now swapped box and ok!!
Page created in 0.04 seconds with 20 queries.
