Author Topic: ??????????????????  (Read 4456 times)
Re: ??????????????????
« Reply #15 on: 20 September 2009, 01:02:19 »
was looking behind the grille at the front, where abouts should it actually be locateded ?????  unsure if it used to work as only had the car a week any pis would be very much appreciated
Be a bit more specific with what car you have. Preface lift or face lift?  :y  :y  :-/
I have two lulling around the gear lever of my Astra shed! I'll photo one tomorrow if you've had no luck in find yours.  :y
kerr01uk
« Reply #16 on: 20 September 2009, 09:10:06 »
from what i have been told its a facelift, the grille is part of the bonnet lol if its not that wire then whats the wire for?????
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
« Reply #17 on: 20 September 2009, 10:27:50 »
How meany wires is it and what type is it square or round?
kerr01uk
« Reply #18 on: 20 September 2009, 10:30:14 »
will try and get a pic, there are 2 wires going to it i remember that much
rustym95
« Reply #19 on: 20 September 2009, 10:33:05 »
sounds like it could be the sensor, dose it come from the wiring from the horns etc?
kerr01uk
« Reply #20 on: 20 September 2009, 10:36:57 »
it hangs down near the washer bottle
rustym95
« Reply #21 on: 20 September 2009, 10:46:05 »
The only wire near there is the fog light wire do they work?, u should see the sensor it only a little thing with wires going in to it, its cliped in. :y
« Last Edit: 20 September 2009, 10:46:49 by Russell_Hill »
kerr01uk
« Reply #22 on: 20 September 2009, 10:47:35 »
the fogs work fine
rustym95
« Reply #23 on: 20 September 2009, 10:53:23 »
well i dont know it could be the sensor wire, its hard to say with out seeing your car, :-/
Welung666
« Reply #24 on: 20 September 2009, 11:02:16 »
Outside temp sensor
Dead centre of the front bumper, 2 blue wires clearly visible when looking straight down :y
Is your sensor missing completely then?
« Last Edit: 20 September 2009, 11:03:03 by Welung666 »
kerr01uk
« Reply #25 on: 20 September 2009, 14:12:26 »
there are no blue wires there is a blue with yellow stripe and brown going into the plugthen 2 plugs going into the washer bottle, its confusing
rustym95
« Reply #26 on: 20 September 2009, 14:23:02 »
that sounds like the spare wires for the lights ( washing the lights) just looked on mine and its the same. :y
kerr01uk
« Reply #27 on: 20 September 2009, 14:31:19 »
so am i looking in the right place? if not do you know where i should be looking? thanks and sorry
rustym95
« Reply #28 on: 20 September 2009, 14:36:37 »
U ee the black thing in the pic that was put on u arelooking for 1 of them, it will be some were on the front, if not then follow the wire around find another one that is lose it may just pop into your hand.
kerr01uk
« Reply #29 on: 20 September 2009, 14:47:45 »
we have found it,unplugged and plugged back in it worked for a bit then f has appered again,think i need to replace it.thanks for all the help
