Author Topic: Engine swap 2.2 petrol into 2.0 petrol  (Read 1384 times)
Jamieo
« on: 24 September 2009, 00:29:26 »
Can I fit a 2.2petrol  as a direct replacement for a 2.0 petrol engine?
Will all the 2.0 electrics fit the 2.2 lump and will the 2.0 ecu etc need to be changed?
Thanks in advance.
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
Re: Engine swap 2.2 petrol into 2.0 petrol
« Reply #1 on: 24 September 2009, 02:00:33 »
Hi you will need the wire loom and ECU, check at a scrapy, some wire are the same but best to get the right wire loom for the engine, ECU has dif setting on 2.2 than 2.0. :y :y :y
Welung666
« Reply #2 on: 24 September 2009, 05:48:19 »
2.2 is DBW so you'd need the throttle position sensor and loom from inside the car. It'd be easier to source another 2.0 to be honest :y
« Last Edit: 24 September 2009, 05:49:08 by Welung666 »
Jamieo
« Reply #3 on: 24 September 2009, 09:31:03 »
I hope that I am not making myself look thick by asking this but what does DBW mean?
« Reply #4 on: 24 September 2009, 09:33:44 »
DBW = Drive By Wire
Electrically controlled by servo motors not directly by a steel cable  ..  :)
Jamieo
« Reply #5 on: 24 September 2009, 09:38:58 »
DBW = Drive By Wire
Thanks, silly me.
Could I fit the 2.2 engine in using the manifolds and other bits from the 2.0 engine as they look the same except for the 2.2 block being taller?
markey mark
  • SLady bitshorpe north lincs
« Reply #6 on: 24 September 2009, 12:14:41 »
dead easy just swop manifolds off 2.0 and some sensors might have to change cam cover  :y
mick-1975
  • nottingham
« Reply #7 on: 24 September 2009, 20:33:57 »
 hi if u need a 2.o l engine i have one already out and it was a good runner ,  :y
Welung666
« Reply #8 on: 24 September 2009, 20:41:47 »
Jamie, have you got a 2.2 lump already?
Jamieo
« Reply #9 on: 25 September 2009, 01:42:39 »
No, not yet.
My engine went in the early hours of tuesday morning, had been running perfectly all night (It is a taxi) until I pulled away after dropping a passenger off when the power dipped and this tapping noise started.
I got the car home and had a look at it later in the day, before looking at it my first hunch was that the timing belt had slipped but I was wrong. All the timing marks line up perfectly.
I then did a compression test and No 1 registered 0, needle didn't move but No's 2 3 & 4 registered nearly 200 psi. It starts but is very smoky and is burning a lot of oil and runs really rough and noisily.
Since I am going to have to replace the engine any way I thought I could possibly replace it with the slightly more powerful 2.2 lump as the 2.0 seems a little under powered when full of passengers and when I am using the car to tow my caravan.
A local breakers has a 2.0 lump for £150 + vat but another breaker has a 2.2 lump from a frontera for £180.
Welung666
« Reply #10 on: 25 September 2009, 05:51:58 »
No, not yet.
I have a 2.2 I'm breaking here, it still running ATM (till tomorrow anyway) with all the correct loom etc..
« Reply #11 on: 26 September 2009, 09:22:53 »
not sure if frontera lump is that same as the Astra/Vectra 2.2 or the Omega 2.2
Jamieo
« Reply #12 on: 26 September 2009, 10:52:25 »
I got a 2.0 engine from my local breakers yesterday and have started removing the old one.
Thanks for everybody's advice.
Page created in 0.023 seconds with 20 queries.
