Author Topic: radio safe mode  (Read 6850 times)
rikki_essex
  • essex
    • 2L gls estate with lpg 20
radio safe mode
« on: 01 October 2009, 15:06:12 »
cant quite remember how to do it i have read a few other posts but they all say hold 0 down and i have no 0 button on mine its a ccr2006 any one know how to enter the code?
regards Rik
golden_delicious
  • Kingston upon Hull
Re: radio safe mode
« Reply #1 on: 01 October 2009, 15:12:41 »
try holding the AS button down as you turn on the unit :y
There are only 10 types of people in the world, those who know binary and those who dont ;-)
mathewst
  • Split, Croatia
    • v40
Re: radio safe mode
« Reply #2 on: 01 October 2009, 15:41:18 »
Golden is right you must hold AS button instead of 0, everything else in the procedure should be the same
Tony H
  • liverpool
  • Black Elites are luurvley
Re: radio safe mode
« Reply #3 on: 02 October 2009, 11:57:27 »
Ignition On radio OFF
Press and hold A.S. turn radio ON
keep A.S. pressed till beep
Enter code using 1,2,3,4. buttons
Press A.S again
Seeemples  :y
Re: radio safe mode
« Reply #4 on: 02 October 2009, 17:21:35 »
Press A.S again
Seeemple
Don't forget to press one more than the code number...
e.g.: code=0123
press button1 once (one more than 0)
press button2 twice (one more than 1)
press button3 three times (one morethan 2)
press button4 four times (one more than 3)
Hope thats clear? :-?
Joem
  • Keighley
    • Omega elite
Re: radio safe mode
« Reply #5 on: 29 July 2016, 18:36:19 »
The radio and key card with radio code simply has xxxx does this mean it doesn't need a code ?
Also holding AS does nothing.
The radio works OK and you can change station but you can't go back to radio if you have played the CD player.
Last point the steering wheel controls don't work
Thanks
Joe
Re: radio safe mode
« Reply #6 on: 29 July 2016, 19:41:52 »
All of my vauxhalls and my orlando had this xxxx on the card.
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
Re: radio safe mode
« Reply #7 on: 29 July 2016, 20:17:03 »
They never had a radio in them....Did they ?
annihilator
  • Wirral
    • Omega Tourer V6
Re: radio safe mode
« Reply #8 on: 29 July 2016, 21:34:46 »
Does it say safe on the mfd if not then it isn't code locked and If you've just bought the car check the wiring at the back of the radio for altered wiring.
Joem
  • Keighley
    • Omega elite
Re: radio safe mode
« Reply #9 on: 30 July 2016, 16:17:34 »
Yes it does say safe mode and bleeps if I try to switch from cd back to radio.
I can stay on radio and change stations from start up.
But steering wheel controls don't work anymore.
I have had the car about a year and yes he battery did go flat.
Regards
Joe
annihilator
  • Wirral
    • Omega Tourer V6
Re: radio safe mode
« Reply #10 on: 30 July 2016, 17:54:51 »
something not right there,should not be able to do anything if it says safe.can you hear the radio stations or just change channels.
download the manual here http://www.opel-niedersachsen.de/pdf/ccr2006_2002.pdf
John.
« Last Edit: 30 July 2016, 17:57:38 by annihilator »
Joem
  • Keighley
    • Omega elite
Re: radio safe mode
« Reply #11 on: 30 July 2016, 19:34:27 »
John.
Yes no problem hearing the radio or the CD player and can control volume direct from radio.
It's not the end of the world and thanks for trying to help
Regards
Joe
Re: radio safe mode
« Reply #12 on: 31 July 2016, 11:16:38 »
IS the radio and NCDC201x - that would explain the code.
Also, if one of those radios, was it working? When did it stop (did you replace anything?).
Joem
  • Keighley
    • Omega elite
Re: radio safe mode
« Reply #13 on: 31 July 2016, 15:33:01 »
It's the NCDC 2013 which has worked perfect even from the steering wheel.
Replaced nothing just the battery went too flat for it to start, I put the jump leads on it and that's when the safe mode message and bleep started
Regards
Joe
Re: radio safe mode
« Reply #14 on: 31 July 2016, 16:01:30 »
Are you getting Radio Safe or Display Safe on the display ever 10s or so?
