Author Topic: Headlining  (Read 1554 times)
Selseybill
  • La Rochelle
    • 2.0 pre face, 2.2 CDX est
Headlining
« on: 04 October 2009, 17:48:32 »
Can anyone tell me how i can get behind the headlining at the front by the windscreen without damaging it.I need to run wire's for a CCTV camera.Also how the hell do you unclip the panels on the posts that are either side of the windscreen
Re: Headlining
« Reply #1 on: 04 October 2009, 17:51:29 »
I'd get to behind the head lining my removing the trim from around the sunroof. The trim just pulls off the A post IIRC, 3 clips I think.  :y
Selseybill
  • La Rochelle
Re: Headlining
« Reply #2 on: 04 October 2009, 17:53:37 »
I haven't got a sunroof. the A posts and rubber door seals seem to be stuck on with super glue gunt.They just wont budge
« Last Edit: 04 October 2009, 17:55:09 by Selseybill »
  • Auckland
    • Mazda MPV
Re: Headlining
« Reply #3 on: 04 October 2009, 17:58:30 »
Unscrew the grab handle over the door. The trim piece is about 4 feet long and made from two different coloured pieces stuck together. IIRC it is held by 2 or 3 spring clips and is slipped in behind the rubber door seal.
Selseybill
  • La Rochelle
Re: Headlining
« Reply #4 on: 04 October 2009, 18:00:56 »
I'll try that tomorrow as i got a fare to do in 15 minutes.cheers
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
Re: Headlining
« Reply #5 on: 04 October 2009, 22:11:10 »
why are you going to put it in roof lining as best way s the wiring loom from mid to back in the boot, lot easier, get a piece of long bendy thick wire lift up bottom corner on mid console push wire under the carpet, lift up back seat and push wire in and attach the wire for cctv to the wire and push and pull wire, about 10min's did it on mine for caravan cam. :y
Selseybill
  • La Rochelle
Re: Headlining
« Reply #6 on: 05 October 2009, 12:01:34 »
It's not for reversing or a caravan,i use the miggy as a taxi.I have the same system fitted to my old taxi so once i can mount the camera no problems.The camera needs to to be mounted by the inside mirror.This way it will cover the hole interior.The pictures will them be sent to the recorder mounted in the glove box. Fitting the camera was a 10 minute in a volvo and a pug 406 but the miggy stumped me on how to remove the A pillar trim.
rustym95
Re: Headlining
« Reply #7 on: 05 October 2009, 12:29:52 »
oh i see, can you not remove the cover were the engine bonnet release is there is a wiring hole there that gose up post A , then remove the handel on the top, remove the rubber trim round the door and you should see the hole. thats were the taix drivers have done it round here. :y
Selseybill
  • La Rochelle
Re: Headlining
« Reply #8 on: 05 October 2009, 13:09:05 »
That helps.is the rubber stuck or just bloody hard to get off
  • Auckland
    • Mazda MPV
Re: Headlining
« Reply #9 on: 05 October 2009, 15:07:19 »
You don't need to remove the door rubber, it has a soft lip that sits over the trim. You just need to fold the lip back out of the way to get the trim off.
My pre-facelift was like that & I have just checked that my facelift is the same.
Page created in 0.063 seconds with 20 queries.
