Pages: 1 2 3 [4] 5 6   Go Down
Author Topic: 2.5TD (BMW Engine) Fan switch location  (Read 14814 times)
smokingomega
  • Leeds
Re: 2.5TD (BMW Engine) Fan switch location
« Reply #45 on: 13 August 2009, 19:41:04 »
Thanks for the advise.
Think I`ll try flushing mine out.
Is it not normal for them to go that high when towing a 1.3 ton caravan up a hill?
Mine has always done it thats all since I bought it 3 years ago. only tow about 3 times a year.
on normal everyday running the temp stays pretty much the same level
« Reply #46 on: 13 August 2009, 19:42:40 »
no idea - i've never been daft enough to own a caravan ;D
certainly, i'd be very concerned above 100c on the gauge at any point
Spearmint
  • Corby
« Reply #47 on: 07 September 2009, 18:33:08 »
I still have this snag so when I got back from work I had a quick look under the bonnet. Now as it's running hot, after a journey, the electric fans are heard to kick in. So, looking under and through I noticed only one was operating. After the fans stopped (and with the engine off of course!) I had a quick poke about with my keys to find the drivers side electric fan is seized.
Could this be the cause of my running temps?
Is it a bumper off job to change?
« Last Edit: 07 September 2009, 18:33:53 by Spearmint »
« Reply #48 on: 07 September 2009, 21:06:39 »
Might not help.
If you can't free yours off, and you pass Brackley, think I have a spare TD one in garage.
As you can imagine, rad out, possibly a/c condenser as well (doubt you be able to make enough room to slide it out)
Omegatoy
  • UK
« Reply #49 on: 07 September 2009, 22:14:47 »
??????????? fans are only sat there not bolted to rads, whip bumper off and they should fall out easily would have thought?
maybe wrong as i only had mine out when i was checking rad!!
the obvious and really only true way to determine what your cars running temp is, is to tech 2 it live data and see what the actual temp is cos the gauges just gordon brown you all the time!! :y
smokingomega
  • Leeds
« Reply #50 on: 08 September 2009, 16:34:27 »
Are the gauges really that bad?
Do they usually read higher than the actual temp or lower?
« Reply #51 on: 08 September 2009, 19:02:17 »
Slam panel etc in way, they have to come out through engine bay
« Reply #52 on: 08 September 2009, 19:03:10 »
The gauge reads high up until the lower marking, and low after midpoint.  The gauges are pretty consistent.
Spearmint
  • Corby
« Reply #53 on: 11 September 2009, 07:48:35 »
So with my constant running temps of about 95'c it's actually running at 105'c-110'c?
So that said, surely it should have blown the HG or something by now?
Wheres the sender unit for the gauge? Think I'll try swapping that.
« Reply #54 on: 11 September 2009, 09:16:03 »
No. Just under 95, temp (ecu and instrument) will claim to be just under 90. Just over 95, and real temp will go up dramatically, reaching 110C by time gauge hits 100C.  Its at this point things are too hot.
Sender, if you want to change it (will do jack-all) is in head (intake needs to come off).  Both engine and dash senders mounted near each other and look same, but dash one only has 1 pin when you remove connector. Soz, can't remember which way round they are - about 75% certain front one is the dash one.
Spearmint
  • Corby
« Reply #55 on: 11 September 2009, 11:44:52 »
Well if they'll not do anything there isn't any point in changing them. What about Tech 2 plugged into the Ecu to confirm if I'm being lied to or not by the gauge? How do I go about getting hold of one?
I can't see any more options really as I've changed pretty much everything in the system.
Spearmint
  • Corby
« Reply #56 on: 14 September 2009, 20:14:56 »
Even though I cleaned out the rad to the best of my knowledge could it still be Fubar inside?
It's as if the rad is just not man enough to cope with cooling the coolant down so maybe a rad change would solve the snag?
smokingomega
  • Leeds
« Reply #57 on: 15 September 2009, 09:03:30 »
Is it better then to run the car with the viscous fan removed? even when towing?
Spearmint
  • Corby
« Reply #58 on: 15 September 2009, 12:38:44 »
I've not been brave enough to try that out yet. I want a fully serviceable cooling system first. :D
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
« Reply #59 on: 15 September 2009, 15:05:10 »
It's certainly a lot quieter if the Viscous as failed & is locked up! :)
Pages: 1 2 3 [4] 5 6   Go Up
