Author Topic: part numbers  (Read 2912 times)
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
part numbers
« on: 15 October 2009, 08:48:31 »
94- 2.0 Omega Intrument assembly Ident PL R1610052 94- X20XEV Omega ECU, ident SC, NT (90510669) R1060072 94- 2.0SE/XE Omega Clutch kit R1020060 94- Auto Omega ECU ident ICT 96017168 94- 4 spd auto Omega Clutch plate 96014187 Face lift Omega Rear light, LH, outer 93177995 94- Omega Aerial cable, 2m long 93172291 94- Y25TD Omega Oil filter 93172272 94- Omega Aerial cable, 2m long 93160392 94- Estate Omega Roof bar 91146483 94-   Omega Mud flap kit front, estate rear 91146475 94- Omega Harness, alarm status monitor 91145775 94-   Omega Mud flap kit front 91145465 94-   Omega Siren alarm 91132279 94- Omega Compact disc radio 91126311 94- 2.5-3.2 Omega Power steering hose, idnet L5 90575972 94- 2.0/2.2D Omega Injector Holder/nozzle 90573868 94-   Omega Sump shield 90573747 94- Y26SE,Y32SE Omega Rocker cover 90573538 94- 2.5-3.2 Omega Bolt, camshaft pully 90573287 94- V6 Omega Oil filter gasket 90573241 94- X20XEV Omega Water temp sensor 90573077 94- 2.0-2.2P Omega Water pipe, insert to block 90572544 94- petrol Omega Accelerator pedal ass 90572523 94- X20XEV Omega Rear timing cover 90571776 94- with aircon Omega Cooling fan housing 90570701 94- 20SE Omega Cam belt 90570371 94- All Omega Throttle valve body hose 90570180 94- saloon Omega Motor, sun blind 90566864 94- 25XE,26XE,30XE,32SE Omega Duct, engine wiring harness 90566854 94-   Omega Multi function display 90565934 94- Omega Mirror glass,plain,RH with wide angle insert 90565906 94-   Omega seat lumba support 90565577 94- Omega Sunroof motor 90565382 94- Omega Battery cable 90564978 94- 25XE,26XE,30XE,32SE Omega Wiring harness 90564977 94-   Omega Battery terminal cover 90564736 94-   Omega Relay dim/dip healamp 90564329 94- L/H solar ray tint Omega Front door glass 90563879 94- saloon Omega Weatherstrip, rear door, RH 90563515 94-   Omega Front crossmember 90563507 94- saloon Omega Weather strip, reare door window,LH 90563279 94- Omega Window channel seal 90563278 94- Omega Front door window seal, LH 90563277 94- Saloon Omega Amplifier,back window aerial  ident DZ, DY 90563190 94- saloon Omega Boot handle, primer 90547414 94- Saloon Omega Towing lug flap,primed 90545055 94- X25XE,X30XE Omega Timing belt tensioner 90543739 94- Omega Relay 90543014 94- Est,exclu auto levelling Omega Shock absorber, rear 90542948 94-   Omega Fuel pipe insert/clip 90542453 94- U2.5TD,X2.5TD Omega Drain plug, ring seal 90542183 94-   Omega Seat belt pretentioner RH 90542142 94-   Omega Door lock, housing 90541340 94- T1000001- Omega Lock link,front door, RH 90540671 94- T1000001- Omega Lock lever, front door, RH 90540666 94- Omega Wheel hub cover bolt set 90539648 94- All saloon petrol Omega Fuel feed pipe 90538782 94- All Omega Fuel return pipe 90538780 94- 2.0P Omega Engine mount L/H 90538204 94- 2.0P Omega Cover, engine mount L/H 90538198 94- saloon Omega Fuel filler grommet 90531750 94- 2.5TD Omega Air con hose 90531383 94- TD Omega Upper manifold induction 90530760 94- 20XE,25XE,26SE,30XE,32SE Omega Fan housing 90530634 94- DTH Omega Gasket,vacuum pump to head 90528598 94- X25XE,X30XE Omega Exhaust manifold for cylinders 1,3,5 90528464 94- X25XE,X30XE Omega Exhaust manifold for cylinders 2,4,6 90528459 94- Estate Omega Roof rail moulding, centre LH black 90526991 94- Estate Omega Towing flap 90526918 94- Omega Jacking point cover, rear, LH, primed 90525565 94- Omega Window regulator, rear,RH 90520250 94- Omega Front seat back 90517088 94- Omega Parking sensor control unit 90513499 94- all models Omega Towbar relay pack, for check control 90513262 94-   Omega Immobiliser control unit bosch 90513242 94-   Omega Drive shaft boot kit, rear 90512953 94- 2.5V6 Omega Camshaft, inlet 90512905 94- Estate Omega Fuel tank sender 90512052 94- X20XEV Omega Throttle valve body 'O' ring 90511972 94- X20XEV-Y25TD Omega Blower, control unit box, ident YQ 90511964 94- all 2.0P Omega Speedo/tacho instruments 90511802 94- U25TD,X25TD Omega Oil filter 90511738 94- X25XE,X30XE Omega Coil pack 6 cylinder 90511450 94- Omega Fuel injection system ECU, Ident NT 90510669 94- -X1999999 Omega Tie rod assembly,LH 90510649 94- Omega headlamp wash nozzle 90510268 94- 20SE,X20SE,X20XEV Omega Caliper slider kit (90009274) 90510085 94- saloon Omega Knob, rear armrest 90509834 94-   Omega Omega 2.0 16V badge 90509794 94-   Omega "Omega 3.0 V6" badge (9) 90509793 94- Estate Omega Harness, rear qtr window anti theft device 90509788 94- Omega Fuel guage 90509695 94- Omega Temperature guage 90509694 94- estate Omega Tank gauge 90509420 94- Saloon R1000001-S1057528 Omega Tank guage unit 90509419 94-   Omega Thrust spring, lock 90509408 94- X20XEV Omega Lamba sensor 4 wire 90509276 94- X20SE Omega O2 sensor LSH24 90509275 94- U25TD,X25TD Omega Induction manifold gasket 90509135 94- U25TD,X25TD Omega Thermostat 'O' ring 90509113 94-   Omega Airbag contact unit, steering wheel 90507514 94-   Omega Clip, sill moulding 90503824 94- Omega Heat shield 90502880 94-   Omega Heater hose 90502846 94- Omega Heater water inlet hose 90502792 94- X20DTH Omega Fuel injection pipe, nos 3 & 4 90502732 94- Turbo diesel Omega Timing chain guide 90502311 94- 2.5D Omega Clip, oil pipe to pipe 90501859 94- U2.5TD,X2.5TD Omega Hose, heater, water inlet 90501635 94- x20xev Omega  Thermostat & housing assembly 92c 90501081 94- 2.5-3.2P Omega Crank vent hose 90501046 94- X25XE,X30XE Omega Crank vent adaptor 90501043 94- 2.0-2.2D Omega Timing gear, crankshaft 90500696 Omega  Gasket engine breather 90500571 94- Omega Hose clip 90500518 94- X20XEV Omega Hose, air injection 90500273 94- Omega Belt Tensitoner 90500229 94- 2.5,.2.6,3.0,3.2 Omega Heater water inlet hose 90499986 94- Diesel Omega Diesel inlet tube 90499469 94- X20XEV Omega Bracket 90499276 94-   Omega Pipe clip twin 90497771 94- 2.0P Omega Drive shaft flange 90497688 94- 2.0P Omega pipe high pressure ident ar 90497493 94- Omega Bolt/regulator 90497200 94- 2.2XE Omega Servo non return valve 90497004 94- X25XE,X30XE Omega Steering return pipe (Opel 951577) 90496
Re: part numbers
« Reply #1 on: 15 October 2009, 09:27:40 »
Whats the point of that lot??
Zonerc
  • stoke on trent
Re: part numbers
« Reply #2 on: 15 October 2009, 09:34:48 »
be very handy if it didnt do your eyes in looking at it ,be ok if in a proper list,but ty anyway :y
rustym95
Re: part numbers
« Reply #3 on: 15 October 2009, 09:38:31 »
cannot put in line used the tex box up, there is more but have to find were the cut of is and put rest on later., can copy and put word search and find what you wont.
Re: part numbers
« Reply #4 on: 15 October 2009, 12:27:48 »
Shouldn't bother mate - get part nšs off EPC - some members have access to EPC.
amba
  • Medway towns
    • German V6
Re: part numbers
« Reply #5 on: 15 October 2009, 16:11:06 »
Think I should have gone to spec saver !!all the text just goes into 1 .
KillerWatt
Re: part numbers
« Reply #6 on: 15 October 2009, 19:11:32 »
I think you'll find you can punctuate and create ordered lists.
As others have said, absolutely no point in trying to read that as it is.
charlie
  • sunderland
Re: part numbers
« Reply #7 on: 15 October 2009, 19:28:56 »
I think these part no. are what a place called vauxhall green parts sell,There web sit as them in a list.
    • 530D M Sport, 330i Coupe
Re: part numbers
« Reply #8 on: 15 October 2009, 19:33:21 »
Part numbers are available from a number of sources (EPC for one) but most of the How-to's on here have accompanying part numbers where required anyway.
Also if the part numbers are 'cut and pasted' from the vauxhall green parts website you will find a lot of them have been superceded.
