Author Topic: EML on my 2.0 16v :-(  (Read 4449 times)
dalyoftelford
  • Telford
« on: 14 October 2009, 19:47:59 »
Driving on the dual carriage way today and car cut out then come on again , but with the engine management light on and auto gearbox warning light !
Got home and tried to start it .. It turned over for a while then started but reved like a bag of s**t !
gave it an hour started fine , drive round the block and the same thing happend again :-(
Any ideas ??
Cheers
Paul
« Last Edit: 14 October 2009, 19:48:19 by dalyoftelford »
joshwyatt
  • Oxford
Re: EML on my 2.0 16v :-(
« Reply #1 on: 14 October 2009, 19:58:24 »
Have you tried the paperclip test? If not, here's the link... http://www.omegaowners.com/forum/YaBB.pl?num=1189022687
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
« Reply #2 on: 14 October 2009, 21:47:53 »
its the cam sensor, dose that on mine, as when cold its fine and when it hot it cuts out, im getting one tomorrow. :y
dalyoftelford
  • Telford
« Reply #3 on: 14 October 2009, 22:36:47 »
Are they expensive mate ?
« Reply #4 on: 14 October 2009, 22:46:17 »
As Josh says, `clip it first before you spend any money :y
dalyoftelford
  • Telford
« Reply #5 on: 14 October 2009, 22:51:04 »
Got a guy coming round tomorrow to do a diagnostic test on it mate :-)
Just curious on prices he says it is cam sensor :-(
« Reply #6 on: 14 October 2009, 23:03:48 »
Cam sensor about £36 on TC and about £43 retail +vat
rustym95
« Reply #7 on: 15 October 2009, 00:34:46 »
im getting geuine one for £25 inc P&P, Vauxhall motor parts.
what year is yous as there are two types with same part number.
« Last Edit: 15 October 2009, 00:37:01 by Russell_Hill »
dalyoftelford
  • Telford
« Reply #8 on: 15 October 2009, 17:49:22 »
Came up on fault code as crank shaft censor ?
Is it easy to change myself ??
cheers
Paul
« Reply #9 on: 15 October 2009, 18:31:47 »
cheers
Paul
Good job you didn't buy the ca sensor because somebody 'guessed' ;D
crank sensor easy on 2.0 if no a/c, fiddly if you have a/c
dalyoftelford
  • Telford
« Reply #10 on: 15 October 2009, 18:35:43 »
I have air con .....
Been looing for a how to !
I have new sensor in my hand , Ive unplugged it and followed the wire to the end but the rest is just guess work :-(
« Reply #11 on: 15 October 2009, 18:38:06 »
the bugger is behind a/c compressor.  doable, but fiddly...
dalyoftelford
  • Telford
« Reply #12 on: 15 October 2009, 18:44:52 »
Cheers ,
I have just rang a mobile mechanic , He has quoted me to fit new sensor, fit to rocket cover gasket and clean breathers
[size=20]£115 :-( [/size]
« Reply #13 on: 15 October 2009, 18:53:27 »
Cheers ,
ring loo-knee instead - most mechanics dont know what they are doing ;)
« Reply #14 on: 15 October 2009, 19:04:58 »
Cheers ,
Thats cheap if he's including the parts.
