Author Topic: Hi emeissions  (Read 9229 times)
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
Re: Hi emeissions
« Reply #30 on: 19 September 2009, 16:33:43 »
Hi I would think it is the air temp sensor, it dose not come up on a code if wearing out, ecu thinks its cold air coming in, should read between 8oms to 10oms, tells ecu to use more fuel or not, the faster the engine the more it reads it faster is colder idle is warmer. :y :y P.s i bourght a resister of e-bay now mine 17% low on emissions. £1.50p.http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=170376231488&ssPageName=STRK:MEBDIX:IT :y
« Last Edit: 19 September 2009, 17:03:55 by Russell_Hill »
mark.adams
  • Cambridgeshire
  • Happy
    • Omega 2.6 V6 Elite
Re: Hi emeissions
« Reply #31 on: 19 September 2009, 19:47:27 »
What value is this resistor and where do you solder it?
Omega 2.6 V6 Elite in Shiny Black
rustym95
Re: Hi emeissions
« Reply #32 on: 19 September 2009, 20:45:49 »
It is 0.10 so withe the orig it makes between 15-20% risistance, just connect it any way, test the risistace when connected. :y :y Oh its the first one only 2 connecson points just b4 the MAF. :y, realy works :y :y
« Last Edit: 19 September 2009, 20:48:25 by Russell_Hill »
mark.adams
  • Cambridgeshire
  • Happy
Re: Hi emeissions
« Reply #33 on: 22 September 2009, 09:00:06 »
I have a question about this resistor enhancement, if it fools the cars ecu into thinking the outside temperature is higher than it actually is ( and it does because i tried it, live data said the outside temp was 65 degrees when it was about 20 degrees), how will that affect the car starting on a cold day???
  • Auckland
    • Mazda MPV
Re: Hi emeissions
« Reply #34 on: 22 September 2009, 09:15:21 »
I may be wrong but I thought that the temperature displayed on the MID came from the sensor under the front bumper & that the air temperature used by the ECU came from the sensor after the air filter (or from the MAF on facelift cars)
I don't think there is any connection between the displayed temperature and the temperature used in the ECU calculations.
mark.adams
  • Cambridgeshire
  • Happy
Re: Hi emeissions
« Reply #35 on: 22 September 2009, 09:32:45 »
This resistor enhancement DOES fit to the MAF, in parallel with the one thats in there...
The displayed temperature i referred to was the temp from the ecu via live data ("My Naff Code Reader")
« Last Edit: 22 September 2009, 09:33:32 by mark.adams »
  • Auckland
    • Mazda MPV
Re: Hi emeissions
« Reply #36 on: 22 September 2009, 10:01:00 »
Oops, sorry. I should have engaged brain before going into print.
mark.adams
  • Cambridgeshire
  • Happy
Re: Hi emeissions
« Reply #37 on: 22 September 2009, 10:11:00 »
Ha ha, no worries, back to the original question tho'
How would that affect cold starting??
  • Auckland
    • Mazda MPV
Re: Hi emeissions
« Reply #38 on: 22 September 2009, 10:23:56 »
If the add on resistor merely corrects a wrong reading then I would think it shouldn't have any effect. If it leaves the ECU thinking that the air is warmer than it actually is then only the person who set up the fuel maps can tell you.
The ECU might use the coolant temperature as well as air temperature so cold starting might not be too badly effected.
My preference would be to replace any faulty sensors with new genuine ones & not try to trick the ECU by messing with its input signals.
rustym95
Re: Hi emeissions
« Reply #39 on: 22 September 2009, 10:24:39 »
I have the instructions of were it go's, and it gose were i said it go's. :y
TonyBrister
Re: Hi emeissions
« Reply #40 on: 24 September 2009, 22:32:07 »
Five weeks now driving a Kia loan car...I want my Omega back  :'(
mark.adams
  • Cambridgeshire
  • Happy
Re: Hi emeissions
« Reply #41 on: 26 September 2009, 15:01:13 »
Still no idea why the emissions are high???
TonyBrister
Re: Hi emeissions
« Reply #42 on: 28 September 2009, 20:39:17 »
No, can't be much left to test.....
Re: Hi emeissions
« Reply #43 on: 30 September 2009, 21:07:03 »
Hi Tony, :y any further forward yet? :-?
TonyBrister
Re: Hi emeissions
« Reply #44 on: 20 October 2009, 18:43:26 »
20th of October now and still no cure. I just don.t know what to do now.. :(
Pages: 1 2 [3] 4  All   Go Up
