Author Topic: Front brake pads with or without brake warning  (Read 1807 times)
sticky
« on: 15 October 2009, 19:34:20 »
Need a bit of help please just fitted front pads and discs to my 2,5 V6 CDX but in doing so failed to fit the pads with brake warning sesors on , rather than wait and re-order built it all back up , everything ok other than the brake waning display on the dash is there a way I can re-set or re-move the warning , pressing R on the stork on start up or switch off it still remains or have i been a muppet and need to refit original new pads
  • Auckland
    • Mazda MPV
Re: Front brake pads with or without brake warning
« Reply #1 on: 15 October 2009, 19:39:48 »
What happened to your old pad wear sensor(s)? You should be able to transfer them to your new brake pads if you are careful.
Don't try to pull them off they will break. Mount the pad in a vice and use a punch to drive the pin out of the spring in the edge of the pad.
« Last Edit: 15 October 2009, 19:41:11 by andyh »
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« Reply #2 on: 15 October 2009, 19:40:08 »
Just fit some pad sensors to the pads you have put in.
Brake lining wear sensors All models  90495144
Retail Price, Normal Trade. Trade Club.
£10.20 £9.20 £7.71
TuBy's new whipping boy.
« Reply #3 on: 15 October 2009, 19:51:50 »
Need a bit of help please just fitted front pads and discs to my 2,5 V6 CDX but in doing so failed to fit the pads with brake warning sesors on ,  ......
All pads come minus sensor wires, they are NOT inbuilt like some car manufacturers. The sensor is a seperate item that clips to the butterfly shaped anti-rattle spring. Make sure you buy the correct sensors though.
« Last Edit: 15 October 2009, 20:03:55 by Andy_B »
dbr
  • north east.
    • 1997. 2.5CD petrol
« Reply #5 on: 15 October 2009, 22:40:53 »
As a quick short term fix to turn off MID warning, cut end off sensor wires and join the 2 wires together.
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
« Reply #6 on: 16 October 2009, 06:26:16 »
would not cut them off if they are ok, would undo the wire joint and put a pin across and tape it up, until you get new brake pads thats if the sensors are ok.
    • 530D M Sport, 330i Coupe
« Reply #7 on: 16 October 2009, 13:47:35 »
Err, think they meant cut the old sensor and join the wires, not the car loom.
sticky
« Reply #8 on: 24 October 2009, 17:49:11 »
Thanks everybody for the advice solved it now with the short term fix of joining wires of the sensors together for now untill these pads are up then I'll make sure I'll get the right ones next time thanks again bye for now . Sticky
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
« Reply #9 on: 24 October 2009, 18:12:12 »
£10.20 £9.20 £7.71
KillerWatt
« Reply #10 on: 24 October 2009, 19:45:11 »
Read above mate, you buy the sensors SEPERATELY from the pads.
In fact, there is nothing to stop you buying the sensors right now and fitting them to the new pads you already have in place.
PS
If you buy from Camberley Auto Factors, they will do you a PAIR of sensors for the same price that Vx charge the TC holders for ONE sensor (it's only a piece of wire).
« Last Edit: 24 October 2009, 19:46:55 by KillerWatt »
« Reply #11 on: 24 October 2009, 21:04:31 »
I thought it was a cable with two wires in it.  ::)  ::)  ::)
