Author Topic: Replacing Drive Belt  (Read 2593 times)
capoMV6
« on: 17 October 2009, 16:23:49 »
Guys how do you replace the auxillary drive belt of a 3.0 MV6?  Step by step and things to look out for will be really appreciated. Please help.  Thanks.
Re: Replacing Drive Belt
« Reply #1 on: 17 October 2009, 16:24:56 »
you need the V6 Cambelt DVD, its in the shop  :y
« Reply #2 on: 17 October 2009, 16:26:14 »
I think the OP is referring to the fan belt (aux belt) ;)
« Reply #3 on: 17 October 2009, 16:28:27 »
bugger your right, i just read the title  ::)
Sorry yes if its just the aux belt its a doddle, best way, is to map out its current route on a bit of paper, then pop it off and put the new one on.
15mm on the tensioner i belive to slacken it off, take old belt off, feed new one on. Helps if you have a second pair of hands.
Also make sure you get the right belt, there are air-con & non-aircon belts.
« Reply #4 on: 17 October 2009, 16:29:41 »
Release the belt tensioner with IIRC a 15mm ring spanner (top left in pic) remove belt and replace.
« Reply #5 on: 17 October 2009, 16:31:11 »
Beat me to it Tunnie. But I got the picture :P :P
« Reply #6 on: 17 October 2009, 16:31:39 »
Good pic  :y
When fitting, things to be careful of is the belt not fully on the water pump. last time i did one it kept trying to slip off.
« Reply #7 on: 17 October 2009, 16:33:33 »
Good pic  :y
Maybe it`s because you`re too tall to get low enough :D
« Reply #8 on: 17 October 2009, 16:34:24 »
Good pic  :y
 ;D ;D
capoMV6
« Reply #9 on: 18 October 2009, 01:42:29 »
Thanks guys. Finally got the old one off. However, there seems to be some burnt plastic around the Tensioner. Does not look like rubber from the old belt. It looks like a plastic shroud or something. :-? :-?
By the way the old belt was shredded.
« Last Edit: 18 October 2009, 01:43:25 by capoMV6 »
« Reply #10 on: 18 October 2009, 02:00:37 »
Looks like your tensioner is seizing - replace it soonest mate!!  Buy just the tensioner pulley - undo the 15mm nut and swap - easy job!
capoMV6
« Reply #11 on: 18 October 2009, 04:38:13 »
Does the tensioner bearing have a shroud or something?
« Reply #12 on: 18 October 2009, 08:41:46 »
from memory it has a small lip on it.
« Reply #13 on: 18 October 2009, 14:45:50 »
Yes lip is black plastic - had a tensioner seize on my saloon - lots of smoke and burning rubber smell!!  Completely melted plastic part of tensioner pulley and shredded belt lengthwise - bit like an elastic band left on running water pump alternator etc!!
capoMV6
« Reply #14 on: 19 October 2009, 01:03:40 »
Yup thats it. So it does come with a lip. Plastic melted all over the bearing.  Anyway one last question guys, how do I install the new bearing? Is there a position I should watch out for or is it a straight replacement job?  Thanks a lot guys!
« Last Edit: 19 October 2009, 01:04:57 by capoMV6 »
