Author Topic: Diff keep or change?  (Read 3145 times)
Re: Diff keep or change?
« Reply #15 on: 26 October 2009, 13:03:49 »
Can someone with access to TIS post up the V6 diff ratios please?
Tunnie, you have it the wron way around; a 2.5 manual fitted with a 2.5 auto diff goes like a rocket because the auto diff is lower geared (4.22:1 compared with 3.9:1 for the manual). Fuel consumption is higher though.
I cant remember the 3.0 ratios, I think the manual is 3.7 but dont know the auto.
I think they are listed on the Eligable cars list, the leaflet scans on ABS
« Reply #16 on: 26 October 2009, 13:05:38 »
yes they are, under technical specs.  :y
« Reply #17 on: 26 October 2009, 13:15:15 »
TYPE
      CLUTCH
DIAMETER
      GEAR RATIOS       FINAL DRIVE RATIOS
                                              1          2                  3                    4                    5               Rev.
Manual (2.5i)       228 mm       3.95:1       2.19:1       1.39:1       1.00:1       0.85:1       3.53:1       3.90:1
Automatic (2.5i)       -       2.40:1       1.48:1       1.00:1       0.72:1       -       2.00:1       4.22:1
Manual (2.5TD)       240 mm       3.81:1       2.11:1       1.34:1       1.00:1       0.76:1      3.40:1       3.45:1
Automatic (2.5TD)       -       2.40:1       1.48:1       1.00:1       0.72:1       -       2.00:1       3.45:1
TYPE
      CLUTCH
DIAMETER
                                      1           2                    3                     4           5                    Rev.
Manual       240 mm       3.81:1       2.11:1       1.34:1       1.00:1       0.81:1       3.40:1      3.70:1
Automatic       -       2.40:1       1.48:1       1.00:1       0.72:1       -       2.00:1       3.90:1
« Reply #18 on: 26 October 2009, 13:59:08 »
2.5 manual and 3.0 auto both have a 3.90 diff according to that so it should make no difference.  :y
« Reply #19 on: 26 October 2009, 16:18:19 »
I stand corrected  :y
Matchless
  • Nottingham
    • A white van
« Reply #20 on: 26 October 2009, 22:52:57 »
So, for max acceleration (and fuel  ;Dconsumption) fit a 4.22 diff from a 2.5V6 auto to your 2.5V6 manual.
Better still, fit a 3.0V6 with the 4.22 diff. ;D
