Author Topic: Headlamp Washers ? !  (Read 2839 times)
Re: Headlamp Washers ? !
« Reply #15 on: 28 October 2009, 09:05:58 »
I have contacted the DfT on retrofitting HIDs, and their views are that any HID retrofit must meet new car standards.  Which means:
HID approved lenses (ie, must use HID headlamp units - so that rules out all ebay upgrade kits)
Washing system, this is primarily due to glare to other drivers, but HID lights do seem to be affected worse than halogens with just a small amount of grim
An automatic levelling system, again to stop glare/dazzling.
Probably be unlucky to get pulled for any, unless you are some kind of selfish idiot and setting them to be an utter nuisance to other road users. But that is DfT's view.
To stop the washers, as others have said, pull the timed relay from the relay box.
« Reply #16 on: 28 October 2009, 14:36:34 »
or its fuse next to it!  ;)  ;)
« Reply #17 on: 28 October 2009, 15:45:11 »
the problem comes when your back to summer again, plug it in, and they won't work cause over the winter would have gunked them up solid, so you will have to take them apart to be cleaned.
Hence i won't do it to ours.
sneakypenguin
  • Birmingham
  • Xbox gamertag MagicGinjaninja
    • 07 Volvo V70 T5
« Reply #18 on: 28 October 2009, 17:31:11 »
Might sound stupid, but can't you turn the headlights off, then run the washer and then turn headlights back on. Maybe like when you're sat at the traffic lights.
this  ;D
07 Volvo V70 T5 SE ex police
FatS
  • nr Chelmsford - ESSEX !
  • sorry about the last avatar :-(
« Reply #19 on: 02 November 2009, 13:26:59 »
Well yes, but, there aren't any traffic lights on my way down the A12  :(
AND, the A12 is a VERY GRIMEY road during Autumn/Winter
months (especially IF they decide to Grit it - once in a
while ! ! ::) )
[ used to have 2.5 MANUAL before . . THAT'S why i've gone for the AUTO :-) ]
