Author Topic: Bad vibration in 2nd & 3rd gears  (Read 2866 times)
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
Re: Bad vibration in 2nd & 3rd gears
« Reply #15 on: 12 November 2009, 00:45:35 »
ok easy way to test propshaft, get a piece of wire and a weight, rap round the propshaft leving weight to dangle, have one person  turn one wheel and one person under the car and look for it moving side to side up and down, if juders a bit put some grease on it so it can slip easy, should be able to test it that way as you said it on stands, allso listen out for clicking as that could be the problem area. :y
« Last Edit: 12 November 2009, 00:47:17 by Russell_Hill »
Blackie_No1
  • Ballyclare N.Ireland
    • Omega Elite 2.5
« Reply #16 on: 12 November 2009, 11:08:28 »
Your a star!!! will have to put the heater on in the garage at lunch break to get it warmed uup for this evening LOL!!
2000 Omega Elite 2.5 V6
Blackie_No1
    • Omega Elite 2.5
« Reply #17 on: 14 November 2009, 00:10:03 »
Candyman got me sorted, either it was a bent prop or the prop had been split and not lined up correctly when refitted, new prop in and it drives like a dream.
Not sure if it is my imagintaion but it even feels faster or mor responsive!!
