Author Topic: EGR  (Read 1743 times)
ENFIELD_MV6
  • Enfield
  • previously from leicestershire
EGR
« on: 16 November 2009, 21:41:42 »
seen some posts regarding of removing the egr and blanking it off ?????? some questions
1, does my 99 mini facelift 3.0 V6 have 1
2, is it easy to remove and blank off
3, what benefits/non benefits on having it or removing it
Cheers peeps
Re: EGR
« Reply #1 on: 16 November 2009, 22:00:53 »
Yours will have one but you can't remove it but you can blank it off ;)
ENFIELD_MV6
  • Enfield
Re: EGR
« Reply #2 on: 17 November 2009, 11:20:03 »
does it benefit the car in anyway by blanking it off or not
  • Auckland
    • Mazda MPV
Re: EGR
« Reply #3 on: 17 November 2009, 13:12:16 »
EGR (exhaust gas recirculation) feeds some exhaust back into the inlet manifold under certain running conditions. I think it is to reduce nitrous oxides (NOx) which form at the elevated temperatures that occur during lean burning cruise conditions.
If it is working as intended then it isn't doing any harm. If you are having random poor starting or stalling problems then it might be cheaper to blank it off than to replace it.
The 2.6/3.2 don't have it but that might be because they have 4 catalytic converters (2 each side)
alenalper
  • Istanbul
Re: EGR
« Reply #4 on: 17 November 2009, 17:59:29 »
if you blank it off , eml  will light up.
if you do this, no eml light..
SUZUKI
GSXR 1000
K6
Re: EGR
« Reply #5 on: 17 November 2009, 18:13:12 »
Blanking it off is usually done by fitting a blanking plate (sometimes made from something like an old coke can) between the valve body and the part whiich runs down to the manifold. :y
« Last Edit: 17 November 2009, 18:13:57 by albitz »
Abiton
Re: EGR
« Reply #6 on: 17 November 2009, 18:28:50 »
Nice work Alenalper, if one wants to remove the thing completely, that looks like the way forward.
I wouldn't want to remove or blank it off personally.
As well as the emissions side of things; surely having EGR gasflow improves closed-loop economy by reducing pumping losses?
Re: EGR
« Reply #7 on: 17 November 2009, 19:46:02 »
Lower compression ratio and slightly more controlled ignition and hence lower cylinder temps resulting in lower NOx without EGR  :y
Page created in 0.032 seconds with 20 queries.
