Pages: 1 [2] 3  All   Go Down
Author Topic: crankshaft sensor(autobox)?  (Read 3812 times)
sexydaz
Re: crankshaft sensor(autobox)?
« Reply #15 on: 15 November 2009, 16:20:09 »
im gonna clean mi switch check all mi plugs to box check oil again now ive done a few miles and look at the winter button,folk keep mentioning selector so ive got my hopes on that.  cheers guys ;)
sexydaz
« Reply #16 on: 16 November 2009, 17:07:22 »
well i cleaned my switch today and nicht,nato,nothing its still the sameim a tad cheesed off nah :(
unlucky alf
  • worksop, notts
« Reply #17 on: 16 November 2009, 17:38:00 »
have you checked the round blue plug by the battery tray, there are 3 plugs side by side, the blue one is g/box connections :y
sexydaz
« Reply #18 on: 16 November 2009, 17:43:01 »
i havent no,thanks im goin for wife in 5 mins il have a quick look  cheers :y
sexydaz
« Reply #19 on: 16 November 2009, 18:38:13 »
dont help being dark but how does that plug come apart
unlucky alf
  • worksop, notts
« Reply #20 on: 17 November 2009, 09:04:08 »
its got a locking collar that twists mate :y
GArlington
  • London, UK
« Reply #21 on: 17 November 2009, 16:41:32 »
yesterday i was given the number of an ex vauxhall mechanic and told hes yer man.ive just spoken to him and explained how my box wont select 1st or go throuigh the gears when in d but i can manually select all the gears and he said is yer eml on(yes) and he said the last one he had like that was caused by the crank sensor ive no reason to doubt him and was wondering if anyone else has had thisand is it an easy job to try another :)
AFAIK crank sensor is the one on the engine's crank, if is NOT working, your engine will NOT start, if it is not working correctly your engine will work VERY badly if at all...
So, I would not think that crank sensor will cause ANY problems with gearbox...
ATF level and worn gearbox clutches may cause such problems, I would check ATF first (much cheaper)...
sexydaz
« Reply #22 on: 17 November 2009, 16:46:27 »
it was all new oil on friday,ive been told today ive a fault in mi wiring
unlucky alf
  • worksop, notts
« Reply #23 on: 17 November 2009, 18:52:59 »
when i first got my mig i had g/box problem [diplayed on the mid] , mine turned out to be the g/box ecu but apparently that is a rarety, double check your switch & multi plugs on the g/box itself as it sounds like the g/box isnt talking to the ecu.
« Reply #24 on: 17 November 2009, 19:39:16 »
Firstly, the 'expert' vx Vauxhall bloke is obviously an idiot.
Secondly, **any** engine related code can stick box in limp.
Get a code reader on both the engine, the gearbox, and the ABS unit, and see whats what.  This MUST be done by SOMEBODY WHO KNOWS WHAT THEY ARE DOING!!!
sexydaz
« Reply #25 on: 17 November 2009, 20:32:54 »
a chap brought some codes up on it and he translated them to if i can remember correctly (can svs requirements,maf sensor signal weak,mixture lean,torque control errors of expensive components)only code i remember is p0100,he reckons theres a fault in wiring,expensive component could be ecu,after cancelling codes when i chose a gear the gearbox light came on,after a few miles that went out and eml came back on
« Reply #26 on: 17 November 2009, 20:34:40 »
Might be worth a trip to Nottingham, and get someone with a tech2 and knows what they are doing to go through it.
sexydaz
« Reply #27 on: 17 November 2009, 20:40:20 »
aye im on the verge of pm,ing mark dtm
« Reply #28 on: 17 November 2009, 20:41:39 »
For the modest cost in fuel, and tech2 fee, its worth it.
ENFIELD_MV6
  • Enfield
  • previously from leicestershire
« Reply #29 on: 17 November 2009, 20:46:08 »
sorry to butt in on the thread, but have read on other threads about having the tech 2 plugged in and sorting the gearchanges out on a auto box ?????? how do you know if it has allready been done ????
Pages: 1 [2] 3  All   Go Up
Page created in 0.024 seconds with 16 queries.
