Author Topic: Bad Mayo or Not !  (Read 3191 times)
Rockhampton
  • Trecelyn, Gwent
  • Gone!
Re: Bad Mayo or Not !
« Reply #15 on: 16 November 2009, 21:39:40 »
ref davethedivers post about removing the filler neck to stop all of this, anyone know who posted it as i would like to do this to mine if its safe. just concerned if you do still get it, this would then go straight into the oil :y
Here it is.. towards the end  :y
http://www.omegaowners.com/forum/YaBB.pl?num=1249377404/6#6
Previous GM Models include '00 Omega 2.5 CD Auto, '06 Holden Commodore Executive 3.6 Auto, '99 Astra 1.8 CDX Auto, several Astra Diesels.
  • Auckland
    • Mazda MPV
« Reply #16 on: 16 November 2009, 21:44:00 »
Perfectly safe, the mayonnaise is a frothy mix of oil, water and air bubbles that formed when the oily vapour from the crankcase condensed in the cool filler neck.
If the filler neck isn't there then there won't be a cool space for the mayonnaise to form (but it does make it more awkward to add oil when needed)
T-rev
  • Grays Essex
    • 2002 Omega 2.6CD
« Reply #17 on: 16 November 2009, 21:52:11 »
thanks guys. i would like help understanding once & for all how to check my breather system though. i have read a few on here but nothing concrete and i dont want to strip things down un-necassarily. daz did do my cam cover gaskets a few weeks ago and said the breathers were clear, but thats when he had the covers off. didnt touch the breather box i have read about at the back to my knowledge..... :-/
pedroMV6
  • York
  • Der Metzgermeister
« Reply #18 on: 16 November 2009, 22:02:58 »
Condensation can cause mayo to build up in the filler neck, it's nothing to worry about. If your HG had gone, it would start to overheat, you would be able to see oil in the coolant header tank.
Anythings possible, but from your description I'd doubt very much the HG has gone.
Spot-on Josh. :y
Because the oil filler sits proud of the engine, it condensates easily - probably when the engine has been run and switched off. The air around it will cool quicker than the air inside it, hence the mayo.
jonnycool
  • Merthyr Tydfil, S. Wales
  • We shag 'em, you eat 'em
« Reply #19 on: 16 November 2009, 22:09:00 »
Get a 'trade card', 20 litres for 15 of 10/40 semi, total £32 from your 'friendly Vauxhall' dealer
regards
richard a
How much is it otherwise? I haven't got my trade card yet  :-[
pedroMV6
  • York
« Reply #20 on: 16 November 2009, 22:14:18 »
About £25 for 5 litres.
**DON'T TELL EVERYONE**Alternatively, get to know a technician at your local VX stealer - it can be got for about 75P per litre...........you'll need your own can though!
**SERIOUSLY!**
« Last Edit: 16 November 2009, 22:15:10 by PedroMV6 »
« Reply #21 on: 17 November 2009, 09:21:45 »
**SERIOUSLY!**
Yes but that wont be the Vx oil, it will be some other cheap stuff they buy in bulk and use on the auto dispense setup in the garage.....it might even be Castrol ( [smiley=shocked.gif])
pedroMV6
  • York
« Reply #22 on: 17 November 2009, 21:13:18 »
**SERIOUSLY!**
True, that's very possible - but I know what I get is the right stuff! :y
