Pages: 1 2 [3]  All   Go Down
Author Topic: Starting problems then won't rev up!!!  (Read 4377 times)
prestigetravel
  • Leominster
Re: Starting problems then won't rev up!!!
« Reply #30 on: 17 November 2009, 21:06:10 »
right, butterflies dont move at all
« Reply #31 on: 17 November 2009, 21:09:48 »
Ok, check wiring to the accelerator pedal
Abiton
« Reply #32 on: 17 November 2009, 21:13:35 »
It could be time to edit the "maybe" out of post #12.
prestigetravel
  • Leominster
« Reply #33 on: 17 November 2009, 21:18:06 »
all seems ok, just tried with pedal unplugged, still same symptoms.
« Reply #34 on: 17 November 2009, 21:20:27 »
only time my throttle pedal failed to actually rev the engine was down to failing cam sensor
« Reply #35 on: 17 November 2009, 21:20:40 »
SO, you need proper diagnostics.....to get live ecu values.
Are all the large connectors at the rear of the battery ok?
ENFIELD_MV6
  • Enfield
  • previously from leicestershire
« Reply #36 on: 17 November 2009, 21:21:10 »
just curious how far are you from jct 25 of the M25, could poss help you out, fresh pair of eyes and all that
prestigetravel
  • Leominster
« Reply #37 on: 17 November 2009, 21:28:06 »
cheers for that but im probably approx 200 miles from you, my mate lives in walthamstow and thats 160 miles from me, cheers anyway
prestigetravel
  • Leominster
« Reply #38 on: 17 November 2009, 21:32:58 »
all battery connections ok. just noticed taped up strap hanging under front as ive moved it, its bolted to front crossmember and at a glance looks like it should go to bolt on engine by sump! have held it to engine whilst wife watches panel, no difference, but know engine earth straps well known for breaking and causing problems. bolt snapped off so will tap it out in morning.
« Reply #39 on: 17 November 2009, 21:35:01 »
Earth straps not known to cause issues on Omegas but...not a good thing!
So, one fault found to address.
prestigetravel
  • Leominster
« Reply #40 on: 17 November 2009, 21:41:40 »
yes, just dragged the wife away from im a celebrity,jacked up front and got her to watch dash again, no change! looks like homemade strap, dont think its part of this issue.
you seem a knowledgeable fella, what would you do? i really want to get driving this beauty!
Pages: 1 2 [3]  All   Go Up
