Author Topic: Petrol tank wont fill up fully  (Read 1641 times)
Omegadoha, Desert Member
  • Doha, Qatar
« on: 24 November 2009, 16:02:14 »
Got a new problem with the petrol tank not filling up properly. Tank was empty today and after about filling up halfway the nozzle cut out as if to say full. Tried filling up at different stations just to see whether it was a one off, but no.
Is there a vent or something on the petrol tank that could be blocked.
waspy
Re: Petrol tank wont fill up fully
« Reply #1 on: 24 November 2009, 18:16:51 »
Are you sure your gauge is accurate. There could be an under lying problem with the float, sender etc
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
« Reply #2 on: 24 November 2009, 19:35:39 »
Tank's probably full of sand! ;D
Almost famous!   www.pitchforkband.co.uk Guitar & PA Amps repaired & serviced
Ears pierced while you wait. PAT & Valve testing
JezInBrum
  • Birmingham
  • Built for comfort not speed
« Reply #3 on: 24 November 2009, 20:27:16 »
Fuel tank vents may be playing up. Part of the filler neck that vents the fumes as its filled up. May be worth seeing if you can push a length of hose down.
Welung666
« Reply #4 on: 24 November 2009, 20:44:11 »
I have a tank sat in the garage if you need any pics Doha ;)
« Reply #5 on: 24 November 2009, 20:46:05 »
The vent pipe runs up to the charcoal canister in the front wing and through a solenoid valve behind the driver's side cylinder head to the inlet manifold. Could be that the charcoal canister or pipe are blocked, I guess.
Andy H
  • Auckland
    • Mazda MPV
« Reply #6 on: 24 November 2009, 21:00:22 »
Are Omega petrol tanks prone to collapsing?
Maybe not in the UK but how about in Doha at 50 degC with the petrol pump creating a vacuum in the tank?
Side Note - has anyone got any details of the tank vent system? When the engine isn't running I believe the tank should vent through the carbon canister to atmosphere. I also believe that the solenoid valve should draw fresh air through canister to purge it of fuel fumes when the engine is running therefore there should always be a permanent vent to atmosphere whatever the valve does. If the permanent vent were to get blocked then manifold vacuum would be applied to the tank when the solenoid valve opened.
mantahatch
« Reply #7 on: 24 November 2009, 21:07:54 »
Have to say that that was my first thought, I would have a good look underneath at the tank for any sign of distortion.
Andy H
  • Auckland
    • Mazda MPV
« Reply #8 on: 24 November 2009, 21:15:34 »
I'm thinking that the weight of the fuel would keep the base down, I'm more worried about the top collapsing.
mantahatch
« Reply #9 on: 24 November 2009, 21:19:27 »
Possibly, but the one's I have seen where virtually sucked dry and so allowed the bottom to move aswell.
It is not a common occurence, but does happen. I hope we are wrong.
