Author Topic: remove door cards??  (Read 2698 times)
Omega3
  • Hertfordshire
Re: remove door cards??
« Reply #15 on: 23 November 2009, 20:20:06 »
Don't know if it's possible for anyone to add this to the excellent door card removal guide?
After removing my 2.2 facelift door cards (using the excellent guide mentioned above) last week to renew central door locking motors there's just one thing I'd like to add though, you do not need to prise out the electric window switch cluster as it is easily damaged leaving ugly scars on the surround. Once the door card is removed you will see a covenient finger hole on the back of the card which allows you to push the switch cluster upwards from underneath. It will just pop straight out which will allow you to remove the connector for the switches and detatch the door card completely.  :)
Thanks for a brilliant guide though, it made it a job I wasn't looking forward to seem easy.  :y
Previously: Mercedes CLK 320cdi, Insignia SRi, 53 Omega 2.2CD, 02 3.2 elite, 01 Omega 2.2CD, 94 Omega 2.0 Est, Mercedes 300TE, Toyota Supra 3.0, Honda Legend Coupe, Supra 2.8i Mk2, Fiat X1/9, Lancia Trevi
« Reply #16 on: 23 November 2009, 20:58:45 »
i merely explained my steps to search the index, and gave the link  :-?
Tut tut Tunnie, being a naughty boy again ;D ;D ;D
Yes, giving the link to the index, and instructions on how to search, is deemed not acceptable by some!  ;D
I notice they are quick to knock and abuse my post, but did they actually post to help in the first place?
Are these lot picking on you again Tun?
I don't mind, this is nothing after the amount of stick i got for being a student  ;D
Or my wiring skills with a Senator & a power inverter  :-X  ;D
Did it glow in the dark?
The gaffer tape did  ;D
« Reply #17 on: 23 November 2009, 21:02:19 »
I think it was the fact the wiring came from under the bonnet along the wing secured with tape and in through the gap between the A pillar and door ::)
« Reply #18 on: 23 November 2009, 21:04:30 »
If it aint broke, don't make it safe  ;D
davey w
  • cheshire
« Reply #19 on: 26 November 2009, 21:09:45 »
Thanks for the link will try and take alook 2moz,hope its not to hard to do as im not to good with the spaners.cheers people. :y
