Author Topic: Faulty rev counter & fuel gauge  (Read 1183 times)
neilr
  • Barnet, Herts
« on: 30 November 2009, 15:53:28 »
hi since replacing the oil cooler on my 2.5 v6 1995 both the rev counter & fuel gauge are working badly its as if there is a loose connection as they flick on and off. is there a common connector or fuse that the both use that i could have disturbed.
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
Re: Faulty rev counter & fuel gauge
« Reply #1 on: 30 November 2009, 17:38:50 »
its more like the connector on the back of the panel, happens some times. :y
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« Reply #2 on: 30 November 2009, 22:59:23 »
i would remove the dash and then push it back into the but conector  :y
rev counter takes its signal from the abs/tc unit and the fuel gauge comes from the sender in the tank  :y
pretty sure the only place they join is at the back of the dash  :y
if that doesnt work, check the earth in the drivers side footwell ( behind the panel / underneeth the bonnet cable lever )
Page created in 0.036 seconds with 20 queries.
