Author Topic: cleaning up after an old oil leak .........  (Read 2598 times)
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
Re: cleaning up after an old oil leak .........
« Reply #15 on: 01 December 2009, 19:15:01 »
For oil stains on the Drive, squirt neat Fairy Liquid on the oil patch leave to soak in for a few days and when it rains you will be amazed how clean your drive can become.
Didn't work for a leak from a Traktor, the black stain is still there on the bricks :'(
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #16 on: 02 December 2009, 13:21:58 »
Try scrubbing with neat shampoo!
Seth
« Reply #17 on: 02 December 2009, 13:25:50 »
It did the job ok then? Is Gunk available in a spray on form as I will be doing this from alternate front sides whilst the car is jacked up.
Gunk actually do two aerosols - foam action and spray action.
I've had excellent results with the foam action stuff, but it seems difficult to get hold of. You'll need to look carefully too, as both types are in very similar cans.
raywilb
  • york. moved to Dalton , Thirsk
    • Citroen C4 Cactus
« Reply #18 on: 02 December 2009, 13:38:25 »
youv,e not said what type of  surface it is. only if its concrete try mixing a bag of mortar mix on top of the stain - but dont do it on sets or tarmac. - being a brickie by trade i found out by accident that it helps get rid oil stains.
I_want_an_Omega
« Reply #19 on: 02 December 2009, 13:46:10 »
I'm talking about getting the oily mess off the underneath of the car - the thread diverged and people started talking about getting it off driveways.
